September 22, 2026, 21:53:00 pm
| |-+  For sale!
| | |-+  Stitch Up Race Car For Sale
Author Topic: Stitch Up Race Car For Sale  (Read 8785 times)
Bernard Newbury
9.50 @ 141 MPH
« on: June 30, 2016, 15:10:18 pm »
It is with great regret that due to family circumstances I am putting my race car up for sale. A lot of you will know the car, but I will post the spec below. The heads have been freshened this year (9 pass’s) with new ti valves and new springs.  No expense has been spared on this car.  There is so much more that will be for sale in the way of spares (many new) clutches, axles,cv’s, fuel pump, pushrods, bearings, head gaskets, ring sets, gaskets, oil pump, valve springs, titanium valves, pistons, ignition components, fuel regulator, NOS solenoids, fittings, jets and much much more.
There are so many items / details it is impossible to list here, so please contact me. Serious enquires only. Car only complete Race ready £ 22,000
Also my Mercedes Sprinter that has been converted as race support motor home is for sale. If you want a complete race outfit with a car ready to run 9’s, trailer, motor homr & tow quad, then this would suit you. Would consider package deal.
Engine Spec>
Autocraft case prepped by Shaun Geers
88mm crank x 101mm bore
Scat flange crank
RLR lightened Flywheel
Carrilo 6” rods
Component Development heads
Titanium valves 54mm 40mm
56mm Berg Carbs
Venolia pistons
Jay Cee cylinders
Autocraft oil pump
Manton pushrods
Jay Cee roller cam
Roller lifters
A1 Custom header
RLR twin disc clutch
MSD Digital 7 Ignition
Extended 7 Qt sump
6.25” Canton large filter
Gearbox> Built by Cogbox
T2
Spool
1>3.10
2>1.93
3>1.41
4>1.04
R/P 4.12
General>
Full cage tagged to 8.50, (in date), 944 lightened cvs, custom made Convertor shop rifled axles, Kirky seat, Neal front brakes, Jay Cee rear brakes, Neal staging brake, Neal hydraulic clutch, Simpson cam lock harness, line lock, Vertigate shifter, Stroud air operated parachute, wheelie bars. Data max 14 channel data logger, NOS Bottle warmer, NX nitrous controller, Nitrous purge, Autometer gauges, Launch and gearshift RPM control, Hoosier slicks, Hoosier front runners,  and so much more. The car has run 9.50@142 with a 1.28 60'
https://www.facebook.com/StitchUpRaceCar/
« Last Edit: June 30, 2016, 15:13:17 pm by Bernard Newbury » Logged
Bernard Newbury
9.50 @ 141 MPH
« Reply #1 on: June 30, 2016, 15:18:54 pm »
#1
Bernard Newbury
9.50 @ 141 MPH
« Reply #2 on: June 30, 2016, 15:19:42 pm »
#2
Bernard Newbury
9.50 @ 141 MPH
« Reply #3 on: June 30, 2016, 15:20:31 pm »
#3
Bernard Newbury
9.50 @ 141 MPH
« Reply #4 on: June 30, 2016, 15:21:26 pm »
#4
71CALRIPPER
« Reply #5 on: July 01, 2016, 15:28:04 pm »
The Advert almost doesn't need any words ..
Bernard Newbury
9.50 @ 141 MPH
« Reply #6 on: July 06, 2016, 11:57:48 am »
Sensible price.
ottobros
« Reply #7 on: August 19, 2016, 08:53:36 am »
Sold and ready to pick up
melvin
OFF/83
« Reply #8 on: August 19, 2016, 18:43:35 pm »
congratz
OFF/83
