September 21, 2026, 17:52:49 pm
| | |-+  12V flywheel for old 1200cc
Author Topic: 12V flywheel for old 1200cc  (Read 13750 times)
Frodo
Life's too short to dance with ugly women!
« on: July 08, 2016, 08:12:49 am »
My '56 is converted to 12V with a 1641cc "F" engine in it. I'm planning to build a 1200cc with an Okrasa-kit for it.
The 1200cc is from the late 50ies with a solid generator-mount. Is there a 12V flywheel that will fit the old engine without too much modification?
Appreciate any tips.
Frode
Member of TVWK and Rüsters VW
RichardinNZ
« Reply #1 on: July 08, 2016, 08:23:40 am »
Is this what you need:
http://aapistons.com/products/porsche-912-356-lightweight-flywheel-200mm-vw-clutch-6v?variant=742286195
Sent from my SM-N920I using Tapatalk
'58 Bug; NZ assembled
Dual Carb 36hp
Frodo
« Reply #2 on: July 08, 2016, 08:46:04 am »
Looks like it. Thanks!
dragvw2180
« Reply #3 on: July 27, 2016, 13:36:03 pm »
 I may have an aluminum one in the attic I would sell cheap if it is needed . Mike McCarthy
« Reply #4 on: July 27, 2016, 16:35:13 pm »
If the engine you're planning to build is based on a late-1950s 30bhp type, then the later flywheel as shown won't fit the crank.
Your simplest option is to run the original 30-horse flywheel with a six volt starter (to match the flywheel) on 12 volts. Or get your 6v starter/solenoid rewound to suit 12v.
Frodo
« Reply #5 on: July 29, 2016, 08:45:35 am »
Yeah, that's what I'm going to do. Did it in the late eighties in my autocross days. Thanks for the reminder, KS.
Chip
« Reply #6 on: July 29, 2016, 13:42:27 pm »
DPR has built a few 200mm 12v flywheels with the 36hp crank flange for land speed racers. I don't know of any off the shelf solutions.
« Reply #7 on: July 30, 2016, 21:36:11 pm »
If I remember correctly, the 6v starter motor will work if you swap the solenoid for a 12v.
