October 01, 2026, 22:46:37 pm
| | |-+  fiting problem with china breather tower
Author Topic: fiting problem with china breather tower  (Read 6598 times)
bzh67
« on: July 15, 2016, 13:27:09 pm »
hello i'm building a 2.3  engine , and test to fit my 356 look a like breather tower on my old engine , but as you see in this pic the tower is not vertical
i think i'm not the only one have this problem
what is the way to put it vertical ?
thanks for your help
neil68
« Reply #1 on: July 15, 2016, 20:15:24 pm »
My Chinese (Latest Rage) breather is not quite vertical as well, but does not lean as much as yours.  I used a rubber O-ring and some RTV silicone sealant to prevent oil drips. What type of seal does your kit use?
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
dragvw2180
« Reply #2 on: July 15, 2016, 21:38:05 pm »
 I hate junk parts. You may be able to make a tapered plate (wedge ) to correct the angle difference .  Mike
Dougy Dee
« Reply #3 on: July 16, 2016, 02:07:37 am »
In the OP's pic it looks like the whole engine is crooked.
Look across the top of the shroud.
Of course it could be the camera angle but the ex studs also look off.
So...possibly the oil breather/tower is close to OK... Roll Eyes
bzh67
« Reply #4 on: July 16, 2016, 11:51:56 am »
ok i found the problem the base of the tower was note really flat
so i drill the base
and now it's ok
neil68
« Reply #5 on: July 16, 2016, 23:54:53 pm »
I forgot about that.  I also took a grinder to my base, in order to get it flatter and for the RTV silicone to bite and seal better.
I hope it works well for you!
Neil
