October 13, 2026, 00:32:33 am
| | |-+  ALS
Author Topic: ALS  (Read 8994 times)
Ghost
ALS
« on: July 23, 2016, 09:31:11 am »
Hi
Did anyone knows if it's possible to use an ALS on a draw through turbo setup?
« Reply #1 on: July 26, 2016, 21:00:46 pm »
I thought about this a few times now but cant think of a way to do it with your set up, time for EFI Shocked Grin
« Reply #2 on: July 26, 2016, 22:06:13 pm »
Everything is possible..
But are you talking about ALS og launch control / 2-step?
Basti
« Reply #3 on: July 27, 2016, 07:04:52 am »
Thats what i sad as well Wink
- black 62 cal look beetle
- Pro Mod Race car
Ghost
« Reply #4 on: July 27, 2016, 08:31:13 am »
I have some problems with a carb so with EFI…
I know what you say but I have a goal with the carb, maybe after perhaps I go to EFI but it's a long way too and here I'm alone…
Actually I have discharge between every shift, I would like to reduce it…
for starting I found, test it in Hockenheim…
« Reply #5 on: July 27, 2016, 11:00:25 am »
how do you do anti lag on draw through carb then Erlend? cant see how you can add fuel and cut ignition at shift when you lift throttle but not done much carb drawthrough stuff so maybe it is possible
« Reply #6 on: July 27, 2016, 11:28:58 am »
Are we talking a bypass valve situation?
I agree that would be tricky  Grin Roll Eyes
But, my initial response was a question if it was ALS or launch. A lot of people use both terms for different thing.
Launch is for building boost stationary, and ALS is to keep the turbo spooling "all the time".
What about fitting a smaller WG?
Ghost
« Reply #7 on: July 27, 2016, 13:34:05 pm »
To ALS I would like talking about turbo spooling "all the time"…
« Reply #8 on: July 27, 2016, 21:17:21 pm »
Just thinking aloud here, and dunno if it would work, but it's 4am and I'm on watch so it's unlikely!  Wink
If it's draw-through set-up, possibly take advantage of the vacuum under the carb at low throttle openings and use it to open an '80s/'90s EGR valve via an electrical vaccuum switch (also '80s/'90s emissions stuff.....wreckers?), which then supplies post-compressor air to the manifold/collector via a simple check valve (vac-u-pan valve?).
