September 24, 2026, 01:37:14 am
NEW SCAT 94/96mm WET CASE with roller lifter mod
Topic: NEW SCAT 94/96mm WET CASE with roller lifter mod (Read 4321 times)
jr59
August 08, 2016, 15:09:06 pm »
So following the heads,
here are a scat case that we puchases years ago,
the case is new comming with the big wet sump,
it's in T4 all main I have the good old mod KS to match it comming withthe case
end paly for flange with copper trust bearing donne
modified by geer for roller cam I ehing that we can go back to flat tappet lifter using bushing in the lifter bore.
comming withthe case a heads up roller cam set up with cam and roller lifter (second ahand set)
It never see oil!! only a crank to mock up!
asking 2000€ negociable for all (case,cam ,lifter and bearing )
don't hesitate to contact me by mail
JR
http://speedshop.skynetblogs.be/#
jr59
Re: NEW SCAT 94/96mm WET CASE with roller lifter mod
August 10, 2016, 08:15:31 am »
I forgot to tell that I'm OK for partial trade for more streetable engine parts (case, crank...)
JR
notchdrag
August 17, 2016, 18:55:38 pm »
Slt JR, pourrais tu prendre contact avec moi quand tu auras le temps, un ami serait peut être intéressé.
jr59
August 17, 2016, 19:21:29 pm »
Ok
Tanks
Jr
jr59
August 19, 2016, 20:41:59 pm »
Sole
Tanks
Jr
