October 14, 2026, 21:56:30 pm
| |-+  For sale!
| | |-+  Leftover / unused parts, berg bus midmount, lasercut parts etc. Offers welcome!
Author Topic: Leftover / unused parts, berg bus midmount, lasercut parts etc. Offers welcome!  (Read 6613 times)
-Alex-
« on: August 08, 2016, 20:39:50 pm »
1: Berg GB 643E 002/091 unpainted midmount (centers the engine - 10mm offset holes) - 130€
2: 002/091 midmount  brackets, 10mm thick - 13€ /each
3: 002/091 rear mount brackets - 13€ /each
4: Swaybar brackets, 80mm height, 70mm bolt hole distance - 16€/pair
5: DRLA/IDF linkage brackets for offset intakes, linkage behind fanshroud - 16€/pari
6: Midmount ym ear brackets, smaller ones 3mm/4mm thick, fit to 50mm diameter rubber,  Bigger ones 4mm thick, fit to 70mm diameter rubber - 15€/pair
7: VW sign big  210mm  - 19€/each, VW KDF sign small  65mm - 12€/each, Triggeriwheel 222x6 - 60-2 - 14€/each
8: Instument panels -  5mm/4mm thick- 100mm big hole and 52m small hole 52mm - 22€/pair
9: Kδfer cup brace brackets/ear - all SOLD
« Last Edit: May 05, 2017, 07:03:43 am by -Alex- » Logged
kafercup
« Reply #1 on: August 22, 2016, 04:40:53 am »
I'd like to buy the Kafer cup welded shock tower extensions.  I'd need the pair shipped to CA 94582.
Sent from my SM-N920T using Tapatalk
-Alex-
« Reply #2 on: February 07, 2017, 19:03:52 pm »
up
-Alex-
« Reply #3 on: February 22, 2017, 14:24:19 pm »
up
-Alex-
« Reply #4 on: May 05, 2017, 07:02:58 am »
up
-Alex-
« Reply #5 on: May 05, 2017, 07:04:01 am »
up
« Reply #6 on: May 05, 2017, 19:29:16 pm »
Number 5... You say the crossbar will be behind the fan shroud? I would like the same thing but in front with offset manifolds. Like normal.
