September 01, 2026, 21:31:03 pm
| | |-+  Best 8 mm head studs: street-strip Beetle
Author Topic: Best 8 mm head studs: street-strip Beetle  (Read 7727 times)
neil68
« on: August 16, 2016, 05:12:46 am »
Had one of my 10-year-old Scat head studs break at the track last weekend. Might be time to replace the set. Hoping to go racing again next weekend and can get these three replacement brands locally. 2332 cc N/A puts out 204 WHP and probably 225 at the flywheel. Any feedback appreciated:
http://store.concept1.ca/Chromoly-Head-Studs-8mm-BP4564/
http://store.concept1.ca/Chromoly-Head-Studs-8mm-CB1229/
http://store.concept1.ca/CSP-Cylinder-Head-Studs-8mm-CSP19803504308HD/
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #1 on: August 16, 2016, 06:16:51 am »
I have been using Raceware on all my engines and I`m boosting it with 30+ psi at times. But if you overtight them you can just as well buy new ones... that said, I`m using a bit more torque than recommended. But then again, I dont use thin wall 94`s.
-BB-
Phil West
« Reply #2 on: August 16, 2016, 07:14:58 am »
I've had no problems with Scat 10172 8740 studs at above those HP levels, Richie stocks them.  Very nice quality.
Phil
« Reply #3 on: August 16, 2016, 07:32:37 am »
Phil
I haven't used the CB or CSP ones so cant comment but I did have some problems with Bugpack ones a couple of years ago stretching when I torqued them up, only odd one or two but wasn't good
as Phil wrote the Scat 190,000 psi version are really good but if it was me for your engine I would get some genuine old stock german ones from an old case and use them
« Reply #4 on: August 16, 2016, 12:55:14 pm »
CSP are the best - high german quality
neil68
« Reply #5 on: August 17, 2016, 00:55:01 am »
Thanks everyone. Of the three available brands, I elected to go with the CSP studs.
Should work well on the street (95% of my driving) and they were also 6 mm longer than the others, which helps with the long rods and JPM head design.
Neil
« Reply #6 on: August 19, 2016, 21:17:00 pm »
Raceware since 1988.......for more than 28 years.
