November 02, 2026, 05:10:41 am
Technical stuff
Jetting advise for 2110 and 45 DRLA's
Topic: Jetting advise for 2110 and 45 DRLA's (Read 9881 times)
PH1303
August 16, 2016, 20:22:11 pm »
Hi
Hoping for a bit of advise from the lounge members. We are going to change my brothers 44 IDF's to 45 DRLA's, and hoping for some recommendations regarding baseline jetting for the Dellorto's. Engine spec are as the following:
82x90.5
5,5" rods
Web 86B
CB 1:1.4 rockers
9:1 static compression
1 5/8 merged header
G03 heads with 39x35 valves
When the engine was almost new, it made 152 hp and 213 Nm with the 44 IDF's. The Dells are with 38 mm venturies...
/Peter
Last Edit: August 16, 2016, 20:26:20 pm by PH1303
Re: Jetting advise for 2110 and 45 DRLA's
August 17, 2016, 02:59:11 am »
Very, very close to my engine spec, but with 48 DRLAs and 36 vents. I have to double check my notebook, but I'm almost positive it's the following:
60 idle
160 fuel
190 air
Depending on a few other factors like altitude and fuel type, it could be a slight bit on the lean side for you. But it will get you on track.
DWL_Puavo
August 17, 2016, 08:51:31 am »
I second Mike's opinion - if you have the most usual 9164.2 emulsion tube, those jettings should be a good starting point. Also 38mm venturies seem like a good size for you heads, cam and engine displacement. You may need 65 idles (~17% bigger than 60) and maybe 170-175 mains (~13-20% bigger than 160). Most usual air correction jet is 180 and it should also be fine.
August 18, 2016, 14:56:51 pm »
I checked my notes, and I'm actually using the 65 idle jet.
PH1303
August 20, 2016, 20:47:02 pm »
Tanks for all the advise. Much appriciated.
We have now checked the carbs, and they are equipped with:
Idle: 58
Main: 160
Air: 200
Emulsion tube: 9164.2
Proberly a bit on the lean side, but maybe okay for start up.
August 21, 2016, 13:22:23 pm »
It'll run like that, but you'll probably need 60-65 and maybe the 180.
