October 12, 2026, 22:47:12 pm
Technical stuff
Damage between valves
Topic: Damage between valves (Read 9877 times)
razoredge
August 21, 2016, 15:35:51 pm »
So what would you guys recommend remove seats weld and cut new seats? I don't want to risk a seat falling out!
Re: Damage between valves
August 21, 2016, 16:48:28 pm »
Definitely. A hairline crack is quite normal but the aluminium has been eroded here. Better safe than sorry!
razoredge
August 21, 2016, 20:40:52 pm »
All the seats have grooves/marks that I won't be able to blend in. The machine work looks like a monkey did it with a spoon, should I go to a vw specialist or will a local machine shop suffice.
August 23, 2016, 00:44:35 am »
Put 37X42 valves in.
razoredge
August 23, 2016, 10:27:19 am »
i am planning on keeping the 40 x 35.5 valves as its a street engine - 125 cam, 78mm crank, heads are currently cut for 90.5 barrels but that might change to 94s
