July 26, 2026, 14:02:46 pm
Feller Service wide 5 disc brakes
Topic: Feller Service wide 5 disc brakes (Read 4602 times)
RaggedyRacing
August 25, 2016, 18:26:31 pm »
Advertising on behalf of a friend that doesn't have an account. I'll try my best to answer any questions, but if you're seriously interested PM me for his number
Quote
Feller Service wide 5 Disc Brakes
Machined aluminium bodies with steel discs
Wide 5 stud pattern (205 x 5) with high tensile wheel studs
Designed to bolt straight onto standard height or dropped DRUM spindles!
New bearing rear dust seals x2
New inner + outer bearings for drum spindles x4
Standard Volkswagen spindle washers x2
Machined aluminium spindle locking nuts x2
Machined aluminium dust caps x2 (one with square speedo cable hole)
Machined aluminium calliper brackets x2 with counter sunk mounting bolts x6
Brembo 2 pot callipers from a 1992 Ducati 750 sport x2 with high tensile bolts + spring washers x4
New calliper dust seals x4
New brake pads x4
Brake pad fitting pins etc x8
Wheel nuts to suit steel wheels x10
I ran these on my old 1964 bug for years with stock steel wheels/south African sprint stars and would recommend using in conjunction with a duel circuit master cylinder.
This very rare French kit is 24 years old and does have some corrosion in non-visual places.
A good upgrade to braking power for your classic Volkswagen beetle up to 1967 plus other VW derivatives using the same size spindles.
Ready to bolt on!
FREE P&P
£1695
"Paint didn't matter, results did"
Hill-Zartman C/GAS NHRA record holders '62 '63' & '64
Re: Feller Service wide 5 disc brakes
August 25, 2016, 20:43:08 pm »
Hi,
Nice set up, can I just confirm price please?
RaggedyRacing
August 25, 2016, 22:04:05 pm »
Quote from: leec on August 25, 2016, 20:43:08 pm
Hi,
Yeah that is what he's asking... not in any hurry to sell, but I'm sure he'd entertain offers
August 25, 2016, 22:11:22 pm »
I was hoping one number was typed by mistake
beetletom
August 25, 2016, 23:08:28 pm »
Quote from: leec on August 25, 2016, 22:11:22 pm
What I was thinking too
RaggedyRacing
August 26, 2016, 09:28:57 am »
Expensive yes, but you won't find another set
