September 23, 2026, 02:00:50 am
Technical stuff
IDA leaking one chamber
Topic: IDA leaking one chamber (Read 8120 times)
chateau la fete
September 11, 2016, 20:02:57 pm »
Hi
After driving my bug then switching off the engine one chamber on only one of my IDA's leaks a small amount of fuel constantly and sits on top of the butterfly. The other chamber on the same carb is perfect and does not leak.
Pump jet??
Any thoughts??
chateau la fete
Re: IDA leaking one chamber
September 12, 2016, 14:00:36 pm »
It's leaking from the chamber nearest to the pump
September 12, 2016, 14:18:07 pm »
your fuel isn't boiling?
happened to me... after shutting down carb temp rizes and fuel starts to boil.
I installed a switch to kill the pump a few hundred meters before I arrive home,
so the chambers are emptied...
chateau la fete
September 12, 2016, 15:11:49 pm »
Good point, but seems strange how it's only one chamber!
