September 23, 2026, 03:02:48 am
| | |-+  header calculation
Author Topic: header calculation  (Read 10808 times)
« on: September 20, 2016, 21:04:04 pm »
Hello Guys,
After reading the small powerhouses topic I was interested in finding the optimal header for my engine.
What I calculated was the following:
Stroke: (Inches)
3.2
Bore: (Inches)
3.7
Number of Cylinders:
4
Exhaust Valve Diameter: (Inches)
1.49
Exhaust Valve Opening Point: (Degrees )
70
Exhaust Valve Duration: (Advertised)
282
Exhaust Valve Centerline: (Degrees)
109
Peak Power RPM:
8000
Volumetric Efficiency:
12.5
 Calculate
Calculated information appears below
Input All Values please
Your Primary Tube Length is 27.33
Your Primary Tube Diameter is 1.25 inches
Your Collector Diameter is 2.16 inches   One Collector
What is interesting for me is the small tube diameter! A chart I found says youi need 1 3/4 in primaries to rev up to 7500..
Am I missing something here? one is perhaps inside dia and the other outside?
some stuff to think about Smiley
JeeWee
the Netherlands
« Reply #1 on: September 21, 2016, 15:05:56 pm »
which calculator did you use?
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: September 21, 2016, 15:11:07 pm »
Sure you punched the right numbers?
1,25" headers does not exist..
You wont be able any way to run 27" primaries, to a collector.
Smiley
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
« Reply #3 on: September 21, 2016, 15:19:32 pm »
All USA built systems are quoted in OD size [as are most others now] which always seemed weird to me as I have seen different wall thickness tubing used over the years
« Reply #4 on: September 21, 2016, 16:27:17 pm »
I'm curious to know how you arrived at 12.5 for volumetric efficiency.
282° exhaust valve duration, is that total? @ .050"? @.020"?
Your engine makes peak power at 8,000? Or is that max rpm?
I think the numbers are entered wrong somewhere.
« Reply #5 on: September 21, 2016, 19:08:58 pm »
thanks for your replies..
got the calculator from here:
http://www.wallaceracing.com/header_length.php
I found the volumetric efficiency on the small powerhouses topic... I could be wrong
282 degrees at 0.050
my heads seem to peak around 8500 on my motor (only calculated intake though) (2276 cc 48 mm valve)
Erlend / bug66
Global Moderator
SCC Event
« Reply #6 on: September 21, 2016, 20:53:23 pm »
Shouldn't VE be alot closer to 100?
The '67:
The '59:
Not yet..
« Reply #7 on: September 22, 2016, 00:10:43 am »
That's what I thought, it was a percentage. If your engine is only 12.5% efficient then 1.25" headers would make sense.
Changing only the VE to 85 gives you 1.61" (roughly 1 5/8") primaries and a 2.8" collector. That sounds more on the right track.
« Last Edit: September 22, 2016, 00:14:03 am by Zach Gomulka » Logged
Erlend / bug66
Global Moderator
SCC Event
« Reply #8 on: September 22, 2016, 07:20:46 am »
I think I used 88% on my last NA engine. Ended up with a Berg 1 3/4 big flange header.
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
« Reply #9 on: September 22, 2016, 07:23:34 am »
Also. Use PipeMax.
If I recall correctly, you can set the lenght of primaries to a set point (normal VW headers are 900-950mm-ish)
And that would correct the diameter needed.
The '67:
The '59:
Not yet..
« Reply #10 on: September 22, 2016, 10:53:47 am »
Cool! thanks a lot!!! Smiley
