October 14, 2026, 00:39:28 am
2276 long block Zero mile rebuild
Topic: 2276 long block Zero mile rebuild (Read 3148 times)
Rocket Ron
It's old school for a reason
October 05, 2016, 19:14:00 pm »
Ali case
Scat chromoly 82 stroke crank with VW journals re ground 1 under 8 dowelled and chromoly 8 dowelled flywheel,H/D chromoly gland nut
Scat H beam 5.4 rods with 3/8 aRP 2000 bolts
Mahle 94mm piston/cylinders
Fk45
Shadeck oil pump,full flowed and blueprinted with full flow cover
manton cut to length push rods
CB wide mouth p/rod tubes
Scat 2 quart deep sump
8mm chromoly head studs
42/37 Welded VW heads ported/polished at Brothers machine
Scat 1.4/1 Pro rock
.570"lift
9.9/1 compression
.044 deck
New rebuild with zero miles.
£3850 Ono
Last Edit: October 07, 2016, 07:12:42 am by Ron Elliot
13.12 @ 101.84
Grooving out on life
Rocket Ron
Re: 2276 long block Zero mile rebuild
October 06, 2016, 10:28:26 am »
13.12 @ 101.84
Rocket Ron
October 06, 2016, 10:33:45 am »
13.12 @ 101.84
