October 13, 2026, 00:32:49 am
| | |-+  what tachometer whith msd6al
Author Topic: what tachometer whith msd6al  (Read 12746 times)
bzh67
« on: October 09, 2016, 09:11:02 am »
hello , when you got a msd6al you need to put the tach wiring on the box of the msd , but all tach doesnt work with the 6AL
can you tell me what tach model do you use on your beetle ?
i've got a JAEGER but doesnt work , i know there is 2 model adaptator but prefer to change the tach directly
please help ,  i just finish my engine , and really need a tach to test the engine on the road
neil68
« Reply #1 on: October 09, 2016, 20:40:28 pm »
I installed a VDO tach with my MSD 6AL and it's worked fine for many years, no issues.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #2 on: October 09, 2016, 21:39:09 pm »
I'd call the Tach manufacturer and see what it would take to make it work -- it would be cheaper than a complete replace,,,,, unless your wanting to update it -- -- go the Summit or Jeg's and look around for something.......
Rocket Ron
It's old school for a reason
« Reply #3 on: October 09, 2016, 22:37:46 pm »
I have an autometer that works fine with my msd
13.12 @ 101.84
Grooving out on life
henk
« Reply #4 on: October 10, 2016, 09:35:38 am »
Same here autometer with my msd.
Henk!!!
BossHogg76
« Reply #5 on: October 10, 2016, 09:50:50 am »
I know you said you wanted to just change the tach, however if you decide not to, i have an MSD 8910 sat in the garage not being used. It's for sale if you want it.
bzh67
« Reply #6 on: October 10, 2016, 22:39:33 pm »
ok thanks for your answers  , so if i could keep my tach i prefer , but dont know if its the pn8910 or pn8920 tach adapter needeed ?
my tach is an olld Jaeger electronic and i have a pretronix ignitor in my Bosch 010 distributor
i use the white wire on the msd6al
BossHogg76
« Reply #7 on: October 11, 2016, 11:48:15 am »
MSD 8920 if you're using magnetic pick up (green and purple wires)
as stated here:
https://www.summitracing.com/int/parts/msd-8920/overview/
MSD 8910 if you're using the white wire
as stated here:
https://www.msdperformance.com/products/accessories/tach_adapters/parts/8910
« Reply #8 on: October 14, 2016, 20:22:28 pm »
    On Page 7 of this .pdf it will show you which tachs are compatible or what you need to get yours to work -- call Jaeger they should know too
