October 13, 2026, 02:47:29 am
Technical stuff
what tachometer whith msd6al
Topic: what tachometer whith msd6al (Read 12756 times)
bzh67
October 09, 2016, 09:11:02 am »
hello , when you got a msd6al you need to put the tach wiring on the box of the msd , but all tach doesnt work with the 6AL
can you tell me what tach model do you use on your beetle ?
i've got a JAEGER but doesnt work , i know there is 2 model adaptator but prefer to change the tach directly
please help , i just finish my engine , and really need a tach to test the engine on the road
neil68
Re: what tachometer whith msd6al
October 09, 2016, 20:40:28 pm »
I installed a VDO tach with my MSD 6AL and it's worked fine for many years, no issues.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
October 09, 2016, 21:39:09 pm »
I'd call the Tach manufacturer and see what it would take to make it work -- it would be cheaper than a complete replace,,,,, unless your wanting to update it -- -- go the Summit or Jeg's and look around for something.......
http://selvedgeyard.com/
Rocket Ron
It's old school for a reason
October 09, 2016, 22:37:46 pm »
I have an autometer that works fine with my msd
13.12 @ 101.84
Grooving out on life
henk
October 10, 2016, 09:35:38 am »
Same here autometer with my msd.
Henk!!!
BossHogg76
October 10, 2016, 09:50:50 am »
I know you said you wanted to just change the tach, however if you decide not to, i have an MSD 8910 sat in the garage not being used. It's for sale if you want it.
bzh67
October 10, 2016, 22:39:33 pm »
ok thanks for your answers , so if i could keep my tach i prefer , but dont know if its the pn8910 or pn8920 tach adapter needeed ?
my tach is an olld Jaeger electronic and i have a pretronix ignitor in my Bosch 010 distributor
i use the white wire on the msd6al
BossHogg76
October 11, 2016, 11:48:15 am »
MSD 8920 if you're using magnetic pick up (green and purple wires)
as stated here:
https://www.summitracing.com/int/parts/msd-8920/overview/
MSD 8910 if you're using the white wire
as stated here:
https://www.msdperformance.com/products/accessories/tach_adapters/parts/8910
October 14, 2016, 20:22:28 pm »
On Page 7 of this .pdf it will show you which tachs are compatible or what you need to get yours to work -- call Jaeger they should know too
