October 13, 2026, 00:04:58 am
914 Porsche gauges in dash
Topic: 914 Porsche gauges in dash (Read 15330 times)
Frenchy Dehoux
October 11, 2016, 08:20:24 am »
Can someone post pictures of Porsche 914 gauges mounted on the dash of a Cal Looker such has the tach and the speedo just want to have an idea how it looks.
Frenchy Dehoux
Doctor Detail ( Retired )
Tobi/DFL
Re: 914 Porsche gauges in dash
October 11, 2016, 08:43:45 am »
Hi Frenchy,
I have a 914 speedo and tach in my ovalwindow.
http://dflvwclub.com/cars.php?lang=en&id=8
Bye,
Tobi
Frenchy Dehoux
October 11, 2016, 08:53:11 am »
Thanks looks nice I am building a 1966 Zenith blue Cal Looker and want to put Porsche 914 gauges in it trying to see various applications.
Frenchy
xavier
October 11, 2016, 11:24:47 am »
There is a thread called Dash Layouts with a nice pic of a DAS Late Looker (Bahama Yellow if I am correct).
It is pretty nice.
Xavier
October 11, 2016, 17:30:41 pm »
I welded in the steel 914 gauge panel to make this.
Straight Time
October 11, 2016, 21:57:50 pm »
I think it is difficult to get all the gauges to work though, am I right ?
No retreat, No surrender !
Ron Greiner
DKP II
October 12, 2016, 00:19:52 am »
HI Frenchy
If you use the 914 or 911 tach, make sure you have them dampened so the needle does not bounce a lot,
I used the 8,000 Rpm 911 tach and had it both dampened and converted to 4 cylinder
October 12, 2016, 00:30:40 am »
Quote from: Zach Gomulka on October 11, 2016, 17:30:41 pm
Looks good. I like placement of starter switch
Rome
October 12, 2016, 00:48:00 am »
Hi, Frenchy, it's Roland from NY. 15+ years since I last saw you- at the Berg's shop, I think! On my non-Cal-Look '77 Std Beetle still with its padded dash, I cut out and moved the stock speedo to the right, then welded in another speedo "collar" to the left to mount a 914 tach. Tach is same size as the stock Beetle speedo. Left enough space in between for two 2 1/8" VDO gauges. Made a cover panel out of thin sheetmetal which is painted in wrinkle-finish black, and screwed to the dash with some black-colored Phillips screws. If you add the chrome rings around both large gauges such as from the '60's, you'd have a unified look for your Cal-Looker. Then try to find VDO Series 1 gauges that have a similar style. Best feature of this gauge arrangement is that all are visible through the steering wheel, and not off to the side or blocked by the rim. That's a '73 SportsBug steering wheel.
Last Edit: October 12, 2016, 01:13:36 am by Rome
Frenchy Dehoux
October 16, 2016, 08:33:30 am »
Thanks Ron and Rome and everyone else for your input on this I appreciate it.
Frenchy
Jos
October 18, 2016, 09:04:39 am »
My car isn't nearly as cool as some of the others posted here and it's not finished yet (I've gotta a lot of final touches like mounting my Blaupunkt Frankfurt and putting in a proper size glovebox door) but here's my attempt at an old school dash....
Frenchy Dehoux
October 19, 2016, 06:14:57 am »
Thanks Jos looks really cool the way you did this one .
Frenchy
October 19, 2016, 07:28:13 am »
I have a speedo in my car I might be talked out of -- I'm going to a GPS one
http://selvedgeyard.com/
October 21, 2016, 10:34:45 am »
Quote from: Rome on October 12, 2016, 00:48:00 am
I really like this!
Larry S
October 30, 2016, 22:02:36 pm »
Frenchy,
I know this is off topic but I recently bought a May 1980 issue of Hot VW's and was looking at the classified section and saw your Ghia listed for sale....That car inspired me to build my Oval Rag that was featured in Hot VW's many years later.
Larry
Frenchy Dehoux
October 31, 2016, 07:28:43 am »
Thanks Larry I wish I had that car today. The car was sold in early 1980 and went to Japan i was hoping someone there would have seen it but as of today no news yet. I have a set of 14 x 5 1 / 2 Porsche alloys I am selling if you know anyone interested. Take care Larry thanks for the post .
Frenchy
AngelzDD
November 08, 2016, 21:58:34 pm »
Here is a car with 914 Gauges. It's the late bug of Der Autobahn Scrapers member, Roland Lebrun ! And the old bug of Twins brother of club!
Larry S
November 08, 2016, 22:44:14 pm »
Frenchy, I sent you a PM about the rims.
Thanks,
Larry
Frenchy Dehoux
November 09, 2016, 20:18:20 pm »
Larry i did not get it.Email me at
Frenchydvb@yahoo.com
Frenchy
