September 23, 2026, 12:42:22 pm
| |-+  For sale!
| | |-+  Old cabrio 2387 turbo engine for sale
Author Topic: Old cabrio 2387 turbo engine for sale  (Read 4850 times)
« on: October 12, 2016, 15:44:42 pm »
For sale turbo engine from old cabrio that I ran 8.95@158mph last year
Just finishing up freshen up and with new engine just about done this will now be spare, I will sell as long block or with header and or intake, also turnkey with ECU and loom complete if required
Specs
CB raised deck highroof case, Flange crank thrust conversion, bmw bearing mods for type 4 bearing crank into type 1 case, 6 head studs,oil pressure relief mods,  all work by Geers engineering
Scat 86mm billet flange crank, type 4 mains, chevy rod journals
Geers billet flange flywheel modded for double disc clutch[can still be used with stock style clutch]
Pauter rods
Pauter 94mm billet cylinders
CP pistons
CB comp eliminator heads, hand ported with 48/40 valves, Ti 8mm stem intake & manley super duty 11/32 stem stainless exhaust, 6 stud, just fitted new valves & springs with valve job etc
Scat 1.4/1 Pro rockers
Scat head studs
Manton super duty pushrods
Fast fab pushrod tubes
Kennedy double disc clutch
Crank trigger front pulley
Sold as long block either wet or dry sump
Or I will sell complete with turbo header with garrett turbo, turbosmart wastegate, header puts turbo forward near front of gearbox on LHS
Then choice of 2 intakes both complete with throttle body and turbosmart dump valve, one to allow stock style [scat 36hp] shroud[made 570hp @ wheels on paradise dyno with this at 26psi boost] and other for no shroud or cooling which made more hp Wink
Finally turnkey with everything except fuel pump
No I am not telling you what cam or lift it has, or what compression is, you want to know then buy it Cheesy Grin  I got 12+ years of development to get it to this point Cool
« Reply #1 on: October 20, 2016, 16:10:03 pm »
Long block sold Smiley
« Reply #2 on: October 20, 2016, 17:33:39 pm »
someone is in for a fast ride next year
« Reply #3 on: November 08, 2016, 17:50:47 pm »
Turbo pending Smiley
