October 12, 2026, 18:51:33 pm
| |-+  Technical stuff
| | |-+  Street weight ERCO's how much tyre pressure
Author Topic: Street weight ERCO's how much tyre pressure  (Read 9066 times)
chateau la fete
« on: October 16, 2016, 08:50:36 am »
What are good pressures for street weight ERCO's running on the street??
Tyres sizes:
Michelin 135 SR 15
Michelin 205 70 15 VR
« Reply #1 on: October 16, 2016, 11:36:23 am »
I'd go for the standard 19psi in the front and 25ish in the back.
« Reply #2 on: October 16, 2016, 12:58:23 pm »
Agree with Neil  Grin
chateau la fete
« Reply #3 on: October 16, 2016, 16:37:10 pm »
No worries, thanks
I currently run around 22 front and 26 rear, tubeless.
I have problems loosing air over a period of time, so am going to use inner tubes
« Reply #4 on: October 16, 2016, 21:12:35 pm »
No worries, thanks
I used tubes in my race weight ones with no problems. On my Saco bolt together front wheels I sealed the two halves together with a 2" wide tape, very much like a really sticky electrical tape and that cured a slow leak that one had.
« Reply #5 on: October 17, 2016, 04:24:49 am »
When Eric gets the wheels from his supplier, they are just two pie plates welded together with no bolt patterns.  After Eric drills the bolt pattern, he lays a large bead of sealant in the groove where the two halves meet.  Maybe yours has degraded.  You could just dig out the old and lay down some new.
« Reply #6 on: October 17, 2016, 06:37:16 am »
No -- you're wrong there -- those rims are drilled and sealed a CMS -- You can buy the halves, but I never heard of Eric bolting them together -- -- you can cure that leak with a thick silicon or break them apart clean them and re-silicon them -- CMS uses about a half of a caulking tube size of silicon per rim........ But like anything, silicon will fracture from flexing on a street rim...
chateau la fete
« Reply #7 on: October 17, 2016, 09:45:00 am »
I agree, the bead has probably de graded some what.
For the use the car gets and only currently running on the street then I'm thinking inner tubes should not  be a problem, only a bit of extra weight!!
May help the ERCO's a bit, what with the amount of pot holes in this country!!
« Reply #8 on: October 18, 2016, 07:44:36 am »
Must've been my imagination then when I was personally standing right beside Eric when he was drilling the bolt pattern on a set of wheels.
This topic is about ERCO wheels, not CMS.  Although CMS makes them for Eric, the wheels they sell may be finished differently.
I never heard of Eric bolting them together either.  Where did you hear that?
