September 24, 2026, 03:27:40 am
Technical stuff
Advantages of MSD ignition?
Topic: Advantages of MSD ignition? (Read 39695 times)
October 30, 2016, 19:05:14 pm »
My Oval wouldn't start today! It has a 2276cc engine, FK87, wedgeports 10.3:1 and IDA's.
Battery charged and spinning motor over fine, almost, and I mean almost fires.
Problem I see is once it doesn't fire, it seems like it results in the motor being flooded. I haven't started it for about 4-5 weeks but before when I used it it fired up first time.
It currently runs a genuine 009 and Bosch blue coil. Could it be the spark isn't man enough to start the motor after a pack of use??
Will a full MSD ignition set up help with cold start as I believe the spark is stronger/larger or can I use just a better coil??
Any thought would be appreciated, except for Danny saying go efi mate
Re: Advantages of MSD ignition?
October 30, 2016, 19:59:17 pm »
I had a 6AL, MSD dizzy and Blaster coil on my race car (2276cc, close enough to 11:1 compression ) and it was good as long as the battery was charged fully. If I didn't top up the charge between runs it would occasionally be difficult to start or have a slight misfire. Don't know if that's any help to you!
DaveN
October 30, 2016, 20:12:59 pm »
go magneto mate
dannyboy
October 30, 2016, 20:17:51 pm »
Quote from: fiat 600 on October 30, 2016, 20:12:59 pm
go magneto mate
8.77@156.8mph
O/FF 60
October 30, 2016, 20:19:47 pm »
Thanks guys.
Even if the battery drops a bit of juice after racing, it will start on the button. It's after a longer period of time not using it (few weeks)
stussyrich
October 30, 2016, 21:40:41 pm »
I recomend a halfords EFI..
Lil Stink Hound.. 2332 IDA. 11.78 @ 112mph.
Turbo Notch.. 2332 Turbo 10.2 @ 137mph.
neil68
October 30, 2016, 22:58:07 pm »
MSD 6AL, distributor & 8.5 mm leads on my 2332 cc and it starts every time. If I get a lot of races during one track night (i.e. 10-12), it will sometimes run my battery down, because I race without the fan belt.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
October 30, 2016, 23:03:17 pm »
Just to be clear, my car starts every time whilst racing, over a weekend, it's just when it's left for a period of time it's a bitch to start.
Going to try a new coil, and then see what happens
October 30, 2016, 23:48:47 pm »
How many times do you pump the accelerator pedal before you start?
Mine use to start bad also, when it hasn t run for weeks, but I now know I have to pump the accelerator 5 times before starting, and it fires up directly.
Took me some time to figure this out.
Dougy Dee
October 31, 2016, 13:06:32 pm »
Points or electronic?
If points, freshen them up. File the faces. How recent is your condenser? Lots of bad ones thru the shop lately...
Electronic? Pull the mounting plate out and check the base for moisture/corrosion.
Good Luck
October 31, 2016, 15:04:53 pm »
It definitely feels ignition based, going to replace coil and check petronix as a first step
Thanks for all the advice (well almost all
October 31, 2016, 21:03:23 pm »
Ever tried to start that whipper-snipper for the first time after some rains? (or in your case, after winter I guess
Some fuels, here in Oz BP Ultimate 98 is crap for this, start to go off when left sitting for longer than a couple of weeks, I notice it in my bikes all the time. If I know it's going to sit for a while I throw in some standard unleaded, lower octane ignites easier. Some brands of fuel here are much better than others for volatility.
Maybe change your brand of fuel?
Rocket Ron
It's old school for a reason
October 31, 2016, 21:15:24 pm »
My bug starts no problem after months standing
Keep,it topped up via a trickle charge but does have full mds set up currently
Magneto was good also
13.12 @ 101.84
Grooving out on life
October 31, 2016, 23:36:50 pm »
Show off
Rocket Ron
October 31, 2016, 23:46:11 pm »
Got a mag here or msd here if you want to try it lol
Msd you get a two step also
13.12 @ 101.84
October 31, 2016, 23:53:01 pm »
Quote from: Ron Elliot on October 31, 2016, 23:46:11 pm
Yep, got an MSD dizzy in the box already, hence I asked this question. A couple of people have said MSD won't make much difference via pm. I think it's either the coil (likely) or the petronix
November 01, 2016, 00:16:23 am »
In my car, moving to capacitive discharge ignition in 1994, made the biggest difference in not fighting the car to get it to fire, when flooded.
I'm guilty of forgetting to remove the air-stack covers on my 48's before I attempt to start the car. Prior to installing the old 6A MSD box, I was running a 009 with Pertronix (I think it was called Per Lux way back then?), with MSD Blaster coil and Denso copper plugs. If I forgot to remove the caps and cranked the motor, while pumping pedal, it was no hope the car would not start (for awhile)after I removed the covers. Once I installed the MSD with everything else remaining the same, it would take a few cranks, but would fire up and clean up quickly.
I have noted once changing from MSD 6A to Crane HI6R digital box (in Dec 2015), the engine will run better at wide throttle openings at lower-mid RPM. I now run a Bosch TCI coil. The plugs are cleaner as well, with carburetor settings remaining identical to MSD settings.
Jim
pupjoint
November 01, 2016, 02:52:37 am »
Has anyone tried this Winterburn CDI?
http://www.thesamba.com/vw/classifieds/detail.php?id=1557647
Jeff68
November 04, 2016, 13:19:07 pm »
^^^^^^I'm curious about the Winterburn Ignition System as well....I have read the documentation and it looks like a well designed ignition system.
November 04, 2016, 16:44:05 pm »
The problem with hard starts are more often than not related to voltage drop to the coil. If an MSD system wohnt start when warm, there is a problem with the unit, even on low voltage.
The issue with low voltage is typically the key assembly. instead of drawing 70-100 W through the key base plate, use a relay and then use the wire from the key as activator. Then you get a much more steady voltage to the ignition system and hard starts are history. - Provided of course that you do not have other problems that really should be adressed.
November 14, 2016, 10:08:59 am »
Swapped the coil for a new one, a slight improvement as it almost ran but still refused to fully fire and run.
We checked the spark, it seems very weak even with the new coil. Any more advice? I running a varley red top 15 battery. My dad suggested rigging up a 'jumper' battery to use as a start up battery? Good idea?
Andrew
November 14, 2016, 12:44:34 pm »
Have you be able to try a new Pertonix?
If the battery tests good I doubt adding a second one will make much difference, a single car battery in good condition has a pretty low output impedance, sure adding another will half it, but half of not very much, is still not very much.
What's the internal resistance of the battery?
Andrew
Felix/DFL
November 14, 2016, 13:16:29 pm »
I didn`t 100% belive in all that multi spark, stronger spark bla bla, till the point I grilled my mallory box (equal as mallory) on a drive.
There was condense water in the box -> ignition on -> bzzzz -> toasted.
I was out with the car so had to unwire the box to make the car drive again. That was easy, but I noticetd when driving without the box that it was not driving so smooth espacilly in the low-middle rev`s. Don`t get me wrong it ran and didn`t had misfire or something liken that, but there was a real difference in how smooth the engine ran with the box.
dragvw2180
November 18, 2016, 21:35:59 pm »
Hey Leec , I have been running MSD on my cars since the early 90's with great results. The first car I used it on was my 1969 911E that I souped up , made it into a 2.4 and added dual 3 barrel Webers . The car was miserable to start after sitting a few days and fouled plugs . I added a Pertronics to the distributor along with an MSD 6T box and matching coil , end of starting problem and ran great . My Turbo street bug has MSD on it also , starts and runs very easily . Is there other stuff that will work as well , probably but with me I see no reason to change. The box I have now is a 6aln HVC I purchased off EBAY for 100.00 USD along with the coil . Mike McCarthy
NoBars
November 20, 2016, 20:19:42 pm »
Quote from: neil68 on October 30, 2016, 22:58:07 pm
I run 16v because I noticed a high rpm misfire at times. I attributed it to running without the alternator allowing the coil to see less than 12v at high rpms, when the coil is drawing a lot of power to "recharge"
Everything works better now, starter, lights. The difficulty is finding a "step up" box to allow the alternator to charge the battery under normal driving.
I also run a 6al, and homemade crank trigger, all MSD components. Never a problem in 11 years.
kever65
November 26, 2016, 09:33:58 am »
Quote from: Felix/DFL on November 14, 2016, 13:16:29 pm
Same here, real difference in driving the car, smoother, no more black spark plugs after long ideling or forgetting to remover carb covers.
January 08, 2017, 19:11:08 pm »
Bit of an update,
Ron Elliot popped round with some bits to swap out and try.
Battery is definitely good, engine turns over fine.
11 volts getting to coil when motor cranking over.
Changed lead from dizzy to coil, some improvement, almost starting
Checked spark on a couple of leads, seems really weak.
We concluded a weak spark is what's stopping it fire.
I am thinking it has to be the pertronix, we ran out of time to try points and see what happens.
Looking at the price of a new pertronix, I have to say I would rather pay a bit more and get the 6al 2.
I already have an MSD dizzy. Would just need the other bits and the 2 step function would definitely help my 60 foot
Rocket Ron
January 08, 2017, 21:04:37 pm »
One thing we didn't try was disconnecting the tachometer from the coil.
Had this problem a few years ago where it was grounding out somewhere from the gauge to the rear of the car this was before I ran the magneto a few years ago.
May be worth a try
Regards Ron
Last Edit: January 08, 2017, 21:06:24 pm by Ron Elliot
13.12 @ 101.84
pupjoint
February 09, 2017, 01:21:28 am »
Quote from: Jeff68 on November 04, 2016, 13:19:07 pm
finally managed to hook up the Winterburn CDI after a year of storing and waiting car completion. car is i fitted in my spare stock 1600 motor so I can drive the car around while waiting for the other motor to be complete. Nothing fancy, stock 1600, 1.5 merged, S&S DQP, Glenn Ring restored 019, stock blue coil, JDM Ultra BP plug cables, NGK BP5H plugs, dual 40 DRLAs. Engine was built by myself in 2011, all stock low mileage late german engine.
I was running on stock points and condenser for a few months and after wiring up the CDI alone, no other changes made, I was impressed with the differences. The response was “instant” throttle felt “lighter”
I am an electronics dummy, so I tried asking Fred, the guy who made them to explain to me what’s the diff between MSD and his version of CDI, I got a long reply that I couldn’t figure out much of the details.
All in all I was happy with the “upgrade”
ignore the black box next to the distributor, it is the old transistor switch box that i have not hooked up.
Andrew
February 14, 2017, 11:17:46 am »
Do you have Fred's reply, I'd be interested.
thanks,
Andrew
