October 14, 2026, 00:37:57 am
| |-+  Wanted
| | |-+  Some body cuts needed from a scrap bug
Author Topic: Some body cuts needed from a scrap bug  (Read 5112 times)
baz
« on: November 06, 2016, 17:22:35 pm »
Looking for a section of rear firewall, about 3 ribs wide and 6 inches tall. Also need 6 wing mount recessed pressings cut around an inch outside recess.
I will prevail.
vwhelmot
« Reply #1 on: November 06, 2016, 18:00:39 pm »
Make a tool to make the wing pressings like I did ?  Getting the square nuts is easy and you just silver solder them in for that correct factory look.
baz
« Reply #2 on: November 06, 2016, 18:04:31 pm »
Where do you get the nuts from?
I will prevail.
vwhelmot
« Reply #3 on: November 06, 2016, 18:23:57 pm »
I had some off some cuts I had. How many do you need?
baz
« Reply #4 on: November 06, 2016, 18:29:31 pm »
I need 6.
The lower holes on the bottom edge of the front and rear quarters  I can press as these are loose repair panels. The other areas I need to fix wouldn't give access for a press tool, they are mid panel?
I will prevail.
vwhelmot
« Reply #5 on: November 06, 2016, 18:44:51 pm »
Do this
Then this
baz
« Reply #6 on: November 06, 2016, 18:51:30 pm »
Do this
Then this
Looks easy eh?  Cheesy
Got some sorted, getting cut right now along with the crossmember and firewall.
I will prevail.
