November 02, 2026, 05:59:47 am
Technical stuff
Leaking Rear Hubs
Topic: Leaking Rear Hubs (Read 5888 times)
RichardinNZ
Leaking Rear Hubs
November 17, 2016, 04:55:38 am »
When I installed the new transmission in the '58 I used new bearings, seals etc in the rear hubs (now with type 3 backing plates, drums and appropriate bearing retainers with the channel for any leaking oil).
I've not had any leaks at all. However, when I pulled the drums earlier this week one side started to leak. Is this usual with the drums off and the axles hanging down with no weight on them, or should I pull it apart and fit a new oil seal?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Dougy Dee
Re: Leaking Rear Hubs
November 17, 2016, 13:56:58 pm »
The o-ring under the seal race/spacer needs the torqued drum to compress and seal it.
I doubt the seal is the problem.
RichardinNZ
Re:
November 17, 2016, 18:15:11 pm »
Many thanks. Hopefully all good then.
Richard
Sent from my SM-N920I using Tapatalk
Dual Carb 36hp
