November 02, 2026, 05:58:26 am
Latest Member: thunder_bac
| |-+  Technical stuff
| | |-+  Leaking Rear Hubs
Author Topic: Leaking Rear Hubs  (Read 5887 times)
RichardinNZ
« on: November 17, 2016, 04:55:38 am »
When I installed the new transmission in the '58 I used new bearings, seals etc in the rear hubs (now with type 3 backing plates, drums and appropriate bearing retainers with the channel for any leaking oil).
I've not had any leaks at all.  However, when I pulled the drums earlier this week one side started to leak.  Is this usual with the drums off and the axles hanging down with no weight on them, or should I pull it apart and fit a new oil seal?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
Dougy Dee
« Reply #1 on: November 17, 2016, 13:56:58 pm »
The o-ring under the seal race/spacer needs the torqued drum to compress and seal it.
I doubt the seal is the problem.
RichardinNZ
« Reply #2 on: November 17, 2016, 18:15:11 pm »
Many thanks.  Hopefully all good then.
Richard
Sent from my SM-N920I using Tapatalk
Dual Carb 36hp
