November 02, 2026, 05:59:47 am
Latest Member: thunder_bac
| | |-+  Gene Berg shifter handle removal
Author Topic: Gene Berg shifter handle removal  (Read 10301 times)
Vdubchef
« on: November 26, 2016, 15:22:20 pm »
Got a Berg 60% speed shifter and want to change the shifter handle. How does it come off? Have taken the shifter out of the car and loosen the two allen screws on the handle. It just rotates but doesn't come out. Is there some trick I should know of?
Also would like to know how do I get the new one on place?
Chef
« Reply #1 on: November 26, 2016, 15:49:08 pm »
You need to release the reverse button from the cable, push the button in and watch the pin at the bottom go upwards, then hold the pin/cable upwards and release button, the button then should slide out. You can now remove handle, fitting new one is reverse Smiley
Vdubchef
« Reply #2 on: November 26, 2016, 19:09:42 pm »
Thanks Richie! Got it!
Chef
« Reply #3 on: November 26, 2016, 23:44:18 pm »
Does anyone know if Berg sell spare parts for shifters? Somewhere I've got an early RHD handle and somewhere else I've got a shifter without a handle, grub screws and button. It's all academic because I've no clue where they are, but it'd be nice to know if I can get the screws and button just in case the other bits turn up!
« Reply #4 on: November 27, 2016, 08:46:47 am »
Yes
« Reply #5 on: November 27, 2016, 19:24:50 pm »
Cheers Richie! One of these fine days I'll have a proper look for it and get the bits ordered.
karl h
« Reply #6 on: November 28, 2016, 11:00:16 am »
communication with berg works like a charm (via mail), just gor my bus shifter. you still get ZOTZ Grin, but there is no more customer number  Tongue
