September 23, 2026, 18:09:27 pm
| | |-+  Impressions of CSP 5 x 205 front discs?
Author Topic: Impressions of CSP 5 x 205 front discs?  (Read 13368 times)
« on: December 16, 2016, 21:50:53 pm »
If you're running CSP front discs, 5x205 style, would you please share your impression of performance, install, servicing/maintenance?
Thank you,
Jim R.
Martin S.
« Reply #1 on: December 16, 2016, 22:28:27 pm »
I just sold a rear Type 3 brake kit to a guy who is running them and he said they were a beautiful kit and worth the money. I'm probably the only one wondering about the weight of these kits as that isn't listed. The cheapo rear disk brakes I have on my swing are super heavy. The rotor/hub alone weighs more than the entire stock brake, then you have a gigantic heavy cast iron caliper to add to that. I can feel the extra weight while driving. Tongue
eugene
« Reply #2 on: December 17, 2016, 08:33:30 am »
Here is a review ad comparison between CSP and AIRkewild type3 front disc brake kit with some info.
http://www.thesamba.com/vw/forum/viewtopic.php?t=633909&postdays=0&postorder=asc&start=0
« Reply #3 on: December 17, 2016, 16:23:51 pm »
My experience with CSP has been nothing short of great but I have nothing to really compare to other then worn-out, stock '67 drum brakes.  Coupled with
Type III rear drum brakes, the car stops as good as the front 145/15 Michelin XZX tires will hold Roll Eyes  The brakes have been on the car for quite a few years now and
I've yet to replace the pads;  I'd recommend CSP.  Don't forget to do your homework on narrowed axle beams and spindles... make sure you've got everything
covered!  For what it's worth, I'm still using a stock '67 master cylinder with no residual pressure valves.  Flexible brake lines are braided stainless with teflon inside.
axam48ida
« Reply #4 on: December 17, 2016, 20:22:01 pm »
I have a set on my oval for the past ten years and they are great.
Olaf A./DFL
« Reply #5 on: December 18, 2016, 13:13:41 pm »
I have the 5x130 CSP Zero Offset front disc brake installed since 2008 and never had any issues - installation was plug 'n play - stops the car precise as it should be - Quality Parts at its best! Smiley
Andrew
« Reply #6 on: December 18, 2016, 14:05:25 pm »
Think of CSP myself. I you have dropped BJ spindles, 5x205 wheels, need to work out which of many kits fits. TUV Approval a good thing.
Read elsewhere that you should change to a master that has a residual pressure valve so interested to hear Sarge runs the stock 67 master.
Anyone fitted a servo? Does it need one?
Andrew
Steve67
« Reply #7 on: December 18, 2016, 16:44:44 pm »
I had them on my 67 with stock rear brakes and stock dual circuit master. The brakes have good quality and bwork very well. The combination with original rear brakes and 145 Firestones in the front is not ideal, the front wheels are blocking very fast. Now I have Type 3 front brakes with 40 mm drums and 19 mm wheel cylinders in the rear which is much better.
I would recommend to update the rear brake as well or at leat run wider front tires.
pupjoint
« Reply #8 on: December 19, 2016, 01:33:06 am »
i fitted a set of US made brake kit. super heavy rotors. absolute rubbish. car doesnt stop any better than with drums, if not worse.  i removed it a week later and replaced with a CSP kit. best thing i have ever done. go German for  brakes.
« Reply #9 on: December 19, 2016, 05:38:21 am »
I did a conversion to KG brakes well before kits were available. Used some junkyard KG spindles and bought everything else new. Dust shields, spindle nuts and center caps came from the dealer. Calipers, pads, bearings, and rotors came from the auto parts store I worked at and I had a set of braided stainless hose made up. I used the '67 master. Me recollection was that it was identical between the Beetle and the KG.
Never had an issue with it.
Tobi/DFL
« Reply #10 on: December 19, 2016, 09:46:39 am »
Hi Jim,
I am running CSP discs on all 4 corners (vented in front) since about 10 years now and can only recommend them if you are looking for a well engineered kit and a trouble free installation. I use the brakes with the recommended CSP master cylinder and the carīs stopping power is superb. The weak link here is the small 155R15 front tyre... Wink
Bye,
Tobi
« Reply #11 on: December 19, 2016, 15:10:42 pm »
I like that CSP has an actual vented rotor.
Andrew
« Reply #12 on: December 19, 2016, 15:59:30 pm »
Hi Jim,
Bye,
Tobi
So the recommendation is to fit them all round to maintain brake balance?
   thanks,
Andrew
« Reply #13 on: December 19, 2016, 17:20:13 pm »
Thanks for all the positive reviews. Sounds like a sure home run. It's the next big step on my '67
Have a good holiday
Jim
Martin S.
« Reply #14 on: December 19, 2016, 17:46:40 pm »
I recommend reading Fred Puhn's book, Brake Handbook cover to cover. You won't regret it. https://www.amazon.ca/Brake-Handbook-Fred-Puhn/dp/0895862328
« Reply #15 on: December 19, 2016, 19:26:34 pm »
I have it, and his handling book.
axam48ida
« Reply #16 on: December 24, 2016, 05:01:51 am »
I got a set for my oval when they first came out. They came with 12mm studs.  I am using a 2" narrow beam with custom steel wheels to give that stock look. I never add any issues and got another zero offset kit for 63. The only bummer is making them work with bubble Erco or centerlines.  I think I got it to work with Erco on the 63. What would be nice Is to mount a 4 or 6 piston wildwood or brembo caliper.
