September 23, 2026, 01:17:38 am
Adding more thread to a press in stud?
Topic: Adding more thread to a press in stud? (Read 8894 times)
January 08, 2017, 19:25:14 pm »
I have started to install some press in studs for my oval. The threaded part of the stud could do with a few more mm of threads cut on it (there is a shoulder before the knurled part that grips the drum)
Is it acceptable to cut a few more threads on it, or does the shoulder need to remain?
Lee
spanners
Re: Adding more thread to a press in stud?
January 08, 2017, 20:24:00 pm »
Stud threads are rolled rather than cut, cutting would be a big no no due to the stress riser nightmare, im not sure of the problem facing you, if its more thread protrusion into the nut you want, you could spot face the back of the disc provided theres meat enough, there usualy is plenty, if the nut is bottoming on the splined section with a wheel fitted, a wheel spacer or shim under the stud shoulder back of the disc, studs do come with various spline reaches though..
Best regards, spanners.
January 08, 2017, 20:51:16 pm »
Thought it would be a no go.
My problem is the wheel nut bottoms out before the wheel is tight. Will have to source another type of stud.
Shame as the ones I have are new/unused
Lee
January 08, 2017, 21:39:47 pm »
Could you have some washers made up like the Erco ones to sit between the wheel and the nut? Or a 3mm spacer between drum and wheel?
January 08, 2017, 21:44:48 pm »
Hi Neil,
Exactly what my dad suggested. Will just source some studs with less of a shoulder (non threaded part)
January 08, 2017, 23:54:51 pm »
These are the type I need, the thread all the way to the splined part. Anyone know any uk suppliers of this type?
http://www.speedwaymotors.com/Moroso-46245-Press-In-Wheel-Stud-12mm-x-1-5-x-3-25-Inch,268939.html
NoBars
January 09, 2017, 01:25:00 am »
Maybe a washer on the stud before you press it in?
UltraOrange67-2443
January 09, 2017, 15:48:20 pm »
Hi dude
I picked some up off ebay.
Can't you use a washer under the wheel nut?
Cheers, Nick
1967 1200 2920cc EFI
January 09, 2017, 23:18:22 pm »
Thank you,
Found these. They look like they will do the job without the need for spacers/washers etc
Any thoughts on these?
http://m.ebay.co.uk/itm/10-x-M12-x-1-5-Knock-In-Wheel-Studs-14-3mm-Spline-50mm-Thread-/182265283595?_trkparms=aid%253D222007%2526algo%253DSIC.MBE%2526ao%253D1%2526asc%253D20150519202351%2526meid%253D9bf8c733fde34786b09c64ffd96a36b8%2526pid%253D100408%2526rk%253D12%2526rkt%253D25%2526sd%253D182265283643&_trksid=p2056116.c100408.m2460
