September 23, 2026, 18:30:40 pm
Technical stuff
Dip stick tube plug
Topic: Dip stick tube plug (Read 6139 times)
Mike P
Dip stick tube plug
January 20, 2017, 20:03:14 pm »
I've got a new universal case that is the base for a new 2007 for a notchback. I was wondering if anyone had an idea as to the best way to plug the dipstick tube for T-3 application. I was thinking about cutting it as close to the case as possible and tapping it for a pipe plug, but it's a little on the small side for 1/8" NPT plug . What are your guy's thoughts on how to eliminate or plug off the dip stick tube. Thanks in advance.
Mike
Re: Dip stick tube plug
January 21, 2017, 01:41:37 am »
Quote from: Mike P on January 20, 2017, 20:03:14 pm
....... and tapping it for a pipe plug, but it's a little on the small side for 1/8" NPT plug .........
Tap it for a metric M8 grub screw?
Mike P
January 21, 2017, 03:59:18 am »
Just what I was looking for. Thanks
January 21, 2017, 20:16:28 pm »
hold on! why not just put on a rubber hose with two clamps and a piece of 8mm round bar (even a screw works), that way you can later use it as a type1 unmodified…
it's what i did to mine.
Mike P
January 21, 2017, 20:30:07 pm »
I've already got 2 other Type 1 universal cases (1 STF case, 1 built into a 2276) so I'm not really that worried about a "permanent" modification. The plugged hose and clamp way did cross my mind I was just trying to find something else.
