September 23, 2026, 20:40:34 pm
| | |-+  Wiper Motor Help
Author Topic: Wiper Motor Help  (Read 9703 times)
Andrew
« on: January 24, 2017, 22:26:54 pm »
I have a two speed wiper switch that is labelled 30, 31, 31b, 53,, 53a and 53b. The switch checks out on all positions on my meter according to the rules.
  • Switch off: 31b connects to ground (via its mounting to the dashboard), 30(+) connects to 53a
  • Slow speed position: 31b is open, 30(+) connects to 53
  • High speed position: 31b is open, 30(+) connects to 53b
I have a four terminal motor, only 3 terminals are connected and 53 and 53b have been jumpered together.
The wiper motor works but only ever at a single speed, could this explain why?
Could I have a broken speed on the motor or was this a common thing to do? Anyone seen this before? Is slow speed so slow that its been omitted?
   many thanks,
Andrew
« Last Edit: January 24, 2017, 22:37:58 pm by Andrew » Logged
alex d
« Reply #1 on: January 25, 2017, 07:57:36 am »
which wiper motor is it? you might have a later one that's not meant to work with the dash mounted switch
UltraOrange67-2443
« Reply #2 on: January 25, 2017, 10:58:11 am »
You may have a 67 single speed.
Are the contact spades all in a row?
Cheers, Nick
1967 1200 2920cc EFI
Andrew
« Reply #3 on: January 25, 2017, 11:26:41 am »
Quote
All in a row and there's 4 of them.
   thanks
Andrew
« Last Edit: January 25, 2017, 14:08:21 pm by Andrew » Logged
UltraOrange67-2443
« Reply #4 on: January 25, 2017, 22:02:05 pm »
That's a single speed 12 volt 1967  Wink
Andrew
« Reply #5 on: January 25, 2017, 22:16:32 pm »
Quote
Ah, that would explain it.
What does a multi speed one look like?
  thanks
Andrew
UltraOrange67-2443
« Reply #6 on: January 31, 2017, 21:55:34 pm »
http://www.socalautoparts.com/product_info.php/aftermarket-windshield-wiper-motor-bug-volt-dual-speed-p-14315
They have contacts side by side rather than a straight line.
ps I've just put my spare N.O.S one in the for sale section.
Cheers, Nick
« Last Edit: February 01, 2017, 20:50:04 pm by UltraOrange67-2443 » Logged
