October 14, 2026, 00:39:56 am
One quick waterboxer for sale!
Topic: One quick waterboxer for sale! (Read 2672 times)
nickedwards
February 10, 2017, 11:56:48 am »
[ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] [ Attachment: You are not allowed to view attachments ] One of the most power Waterboxer's ever made is for sale, It was originally Marco Mansi's motor and was developed and re-engineered for 5years in his street car finally running 10 second 1/4's, then was sold to Matt Keene and installed in his All Torque race car, with further development from Matt and Marco the final output was a staggering 640hp and 550ftlb!! Completing the 1/4 mile in just 9.5
Could be used as is or downtuned a little for an amazing street setup.
ENGINE LONG BLOCK SPEC
2120cc waterboxer
94mm custom Ross pistons
76.4mm forged Oettinger crankshaft
Scat H beams 5.4in ARP2000 3/8 bolts
JPM custom camshaft
T1 scat lifters
Lifter bores sleeved
Autocraft duel taper pushrods
Scat pro 1.4 rockers
K800 springs with modified spring retainers
Stock vw head castings heavily modified
45mm x 40mm Nimonic 80c valves
Raceware 210,000psi headstuds
1/2in custom case studs
Custom piston oil squirters
Custom cam and lifter oil squirters
30mm Gene berg oil pump
Stainless full flow pump cover
Scat stainless valve covers
INTAKE AND TURBO SPEC
Full custom intake with 8x 660cc injectors 2per runner
Custom fuel rails
56mm Cosworth throttle body
800hp rated charge cooler
1,5/8in stainless header, turbo over gearbox
Holset HX40 super turbocharger
ECU SPEC
WOLF 3d v4 ecu with custom wiring harness
MSD coilpack
8 x 660cc injectors
GEARBOX SPEC
915 Porsche gearbox with limited slip diff
Custom flywheel
HD modified Porsche 215mm aluminum pressure plate
Stock 915 disc-needs replacing
Completely ready to run
Engine and Gearbox combo sold together
£8500
Engine alone £6500
Gearbox alone £2500
Complete setup ready to put in your car, with just a few weekends work you could be ready for the season. You cannot go faster cheaper!
Last Edit: February 10, 2017, 12:02:57 pm by nickedwards
