April 23, 2024, 12:09:08 pm
chicochemxli
Technical stuff
efi fuel systems
Topic: efi fuel systems (Read 14819 times)
broen messiaen
Re: efi fuel systems
Reply #30 on:
February 21, 2017, 07:40:05 am »
thanks for the reply.
so one more sensor going in
a 0-150psi one is good?
Last Edit: February 21, 2017, 07:43:34 am by broen messiaen
Chip
Reply #31 on:
February 21, 2017, 12:30:19 pm »
Quote from: broen messiaen on February 21, 2017, 07:40:05 am
Should be just fine
baz
Reply #32 on:
March 02, 2017, 18:25:28 pm »
Quote from: UltraOrange67-2443 on February 13, 2017, 22:34:18 pm
I got this kit
https://www.aeromotiveinc.com/product/phantom-200-stealth-fuel-system/
I pulled the trigger on one of these, hope they are as good as they look. The stealthy in tank appeals to me and this should better than anything knocked together by me.
Have you fitted yours yet?
I will prevail.
Garrick Clark
Reply #33 on:
March 27, 2017, 21:29:48 pm »
Hi guys , I have a fuel issue on my turbo bug ,
I'm thinking its the tank vent
Did a search and this thread came up.
My question is , Is the breather vent pipe on a 67 bug fuel tank good enough for turbo use .
I seam to be going lean high up the revs and cant find any reason for it.
I'm using a stock 67 tank
CB fuel out/return in place of the stock out let pipe
Big bosch pump
8mm fuel pipe to carbs
8mm fuel pipe back to tank
FPR014 reg.
Air cooled Engine builder
Reply #34 on:
March 27, 2017, 22:21:45 pm »
Quote from: GARRICK.CLARK on March 27, 2017, 21:29:48 pm
No chance, well not unless that turbo engine only makes about 150hp max
Reply #35 on:
March 28, 2017, 00:31:32 am »
I have a stock CSP tank on 400whp. No breather mods.. And fat as a pig through out the range..
Garrick Clark
Reply #36 on:
March 28, 2017, 06:49:30 am »
Thanks guys. Think I'll make it bigger to eliminate it as a potential problem.
broen messiaen
Reply #37 on:
April 13, 2017, 19:18:31 pm »
hello, i have a question about the fuel regelator that fit's in this topic
My regulator has a boost reference line, if the engine is na. Do you need to block this or is it better to let it open (so it has atmospheric pressure)?
Reply #38 on:
April 14, 2017, 12:38:35 pm »
let it open
wph
Reply #39 on:
April 14, 2017, 15:18:17 pm »
Quote from: broen messiaen on April 13, 2017, 19:18:31 pm
Your Fuel map will be easier to set up if you add vacuum line from all intake runners to your regulator, Fuel pressure will be referenced to manifold pressure. Transitions on low load and high manifold pressure are more linear, effects are probably most noticeable in driveability.
broen messiaen
Reply #40 on:
April 15, 2017, 08:40:43 am »
Hello, thanks for the reply.
So i made a vacuum box and have vacuum line on every cilinder now.
From the box i will go to the pressure regulator.
Should it be good to put a line to the map sensor also from the box?
Verzonden vanaf mijn iPhone met Tapatalk
wph
Reply #41 on:
April 15, 2017, 09:02:27 am »
Quote
Yes, it will dampen unwanted pulsing of map- signal. To smooth the signal even further you can put simple paper element fuel filter in the map sensor vacuum line.
broen messiaen
Reply #42 on:
April 15, 2017, 09:28:40 am »
Thanks man, just did it.
When it works i will change the hoses to real vacuum hose so it's a bit cleaner.
Now on to the next problem 😉
