September 24, 2026, 08:51:02 am
Technical stuff
Engine building tips
Topic: Engine building tips (Read 10662 times)
andrewlandon67
March 23, 2017, 04:58:49 am »
Well, I'm getting close to ready to rebuild my 1914 here in a few weeks, and I was looking for some tips on how to get it all together right, i.e.; where should I check for clearances, what should or shouldn't be clearanced if I do have some issues, etc.
For the record, my motor is: std/std Universal case, never been built, full flow, EMPI 69mm forged cw crank, h/d stock-length rods, 94s with crosshatching still on the cylinder walls, FK-8 cam, 1.4 rockers, EMPI GTV-2 stage 1 heads milled down to 50cc, dual valve springs, CB .058 Chromoly pushrods, Schadek 30mm oil pump, new oil cooler, etc.
Mostly I'm worrying about how to check for/correct coil bind and valve height, and make sure everything fits comfortably inside the crankcase.
Thanks for any help!
14.877 @ 88.85 mph
He who waves at 911 drivers
Re: Engine building tips
March 23, 2017, 20:31:10 pm »
The biggest problem I have encountered building engines are crankshaft and rods clearance. I have to rebuild a 1641 and a 1300 both with oil pressure problems after only a few thousands km
They are a lot of tutorials around and a very good post on here but can't find it. I think Jim Ratto wrote it
March 23, 2017, 21:25:41 pm »
Hi guys,
I was doing some work helping a friend out a few years back and did some stuff on Facebook for him. maybe this will help?
https://www.facebook.com/pg/goodbetterbestautoparts/photos/?tab=album&album_id=528651577272669
https://www.facebook.com/pg/goodbetterbestautoparts/photos/?tab=album&album_id=529106277227199
https://www.facebook.com/pg/goodbetterbestautoparts/photos/?tab=album&album_id=530455747092252
https://www.facebook.com/pg/goodbetterbestautoparts/photos/?tab=album&album_id=541222172682276
I think you can see all of them here:
https://www.facebook.com/pg/goodbetterbestautoparts/photos/?tab=albums
Have fun
Last Edit: March 23, 2017, 21:27:52 pm by Jim Ratto
March 23, 2017, 22:16:28 pm »
Thanks Jim. All good info are always valuable
andrewlandon67
March 25, 2017, 05:53:24 am »
Damn, that's quite a bit to soak in... thanks for the info, Jim! Since this is going to be the first high-po motor that I've spec'd out and built, I definitely want to make sure that I'm doing everything exactly right, which means tomorrow might be spent digging around work for some of this equipment...
14.877 @ 88.85 mph
viNce
March 25, 2017, 20:49:54 pm »
Hi,
3 years ago, I detailled my 2165 bus engine build on TheSamba, it may help you :
https://www.thesamba.com/vw/forum/viewtopic.php?t=579257
Vince
March 25, 2017, 22:52:52 pm »
I really enjoyed reading your build-up Vince, thank you.
March 26, 2017, 09:41:49 am »
^^^^^^^^^ I agree with the above, nice documentation.
