September 02, 2026, 02:36:25 am
| |-+  For sale!
| | |-+  1957 RHD VW Oval Beetle Turboed Cal looker
Author Topic: 1957 RHD VW Oval Beetle Turboed Cal looker  (Read 4974 times)
JoeHurley1892
« on: April 04, 2017, 21:35:12 pm »
I am selling this on behalf of a friend, so the description are copied and pasted of what he sent me.
1957 cal looker oval
s-l1600 by Hurley Photography, on Flickr
s-l1600-11 by Hurley Photography, on Flickr
s-l1600-8 by Hurley Photography, on Flickr
s-l1600-9 by Hurley Photography, on Flickr
s-l1600-5 by Hurley Photography, on Flickr
s-l1600-4 by Hurley Photography, on Flickr
s-l1600-7 by Hurley Photography, on Flickr
s-l1600-6 by Hurley Photography, on Flickr
1957 oval matching numbers shell and chassis
I have folders off paperwork and receipts from Germany and the U.K., original German Volkswagen paper work and all sorts,
Including what I think to be the original bill off sale
Spec
Paint is new but not 100percent perfect
Has Been converted to rhd at some point but very well done
Adjustable beam
Flat 4 Fuchs , firestones on the front and treaded Hoosiers on the back with a few other almost new tyres to chuck in
Half buckets
Original steering wheel, sun visor/mirror ( in original condition I think )
Original steel bonnet although smoothed
Steel full w decklid
Steel oval doors
Repo rear wings
Day moulding front wings
Lexan lightweight headlight glass
Ally lightweight running boards
Floor pans have replaced with good quality ones at some point in its life
Had two new heater channels by the previous owner
Customer ally interior paneling
Brand new Simpsons harness
Jaymar throttle pedal
Few gauges
Gearbox was sold to me as
1600
3.88 r&p
Longer 4th gear
Split bus lsd
Short axels
It has recently had new wheel bearings and seals ect
Gene berg shifter
Engine
1500sp case drilled for 10mm case savers and full flow
28mm hd oil pump
Mahle 1641 forged Pistons with barrels
Scat h beam forged con rods
Scat lightweight lifters
C25 cam
043 heads, turbo prepped and opened exhaust Ports, heavy duty valve springs
Garret T25 turbo
Multi point fuel injection
dta management
Renault 21 turbo throttle body with custom inlet manifold
Custom under body drip tray
Custom tourqe bar with solid mid mount and gearbox strap
Deep sump
Kendedy stage 1 clutch with scat 4 puk disc
Custom breather box
External oilcooler and remote fan
All braided hose and mostly an fittings
I'm sure I have forgotten loads but it gives you an idea on the car
To Finnish it needs the engine auxiliarys putting back on, ie turbo ,fan housing ect
It's needs underselling
Needs to be mapped
A new rear valence
And paint touch ups
Selling on behalf of a friend
Located near Sudbury, United Kingdom
£12,000
If interested please contact by the following:
Email : Ashleythomsontattoo@yahoo.co.uk
1975 Late Looker HOT 1200 Build Thread: http://cal-look.no/lounge/index.php/topic,20214.0.html
