September 22, 2026, 19:38:30 pm
| | |-+  Mods please close - wrong sect
Author Topic: Mods please close - wrong sect  (Read 5899 times)
Richierich56
« on: April 07, 2017, 01:09:17 am »
Hi all. Sorry this will be a bit long. I am at my wits end at the moment. Just got motor back in - transmission is a type 1 with an early style release bearing. Kennedy Stage 2 pressure plate (with the ring attachment on the fingers for early type release bearing) and new Daikin Super disc.
My issue is - I have set the clutch pedal free play to the correct amount (at the pedal) however, when the wingnut is adjusted to set this amount of play at the pedal the arm on the transmission literally will not move towards the front of the car (with your fingers from underneath) obviously meaning that the release bearing is hard against the pressure plate ring. If I back the wing nut off a turn I cant get gears without crunching and really having the pedal down to the floor hard.
Obviously, this will kill the release bearing in quick time. Someone on thesamba suggested that the arm is indexed wrong on the splines on the cross shaft for the release bearing fork. Does this sound feasible?
Bowden tube is in place with the correct amount of bend, clutch cable is good. I just cant understand what is going on here.
Any help would be greatly appreciated as I am really stuck with this. Anyone have any suggestions at all???
Rich
« Last Edit: April 07, 2017, 14:09:56 pm by Richierich56 » Logged
spanners
« Reply #1 on: April 07, 2017, 17:21:45 pm »
sounds like the friction plate is too thick, spec for new unworn is 9mm/9.6mm unloaded, stock specs but the range crosses over to hypo aftermarket, if yours measures at much over 10mm , theres your problem, thinner disc required, ive measured aftermarket discs at 12mm Huh (some, not all i should say)
« Last Edit: April 07, 2017, 22:03:12 pm by spanners » Logged
Best regards, spanners.
