September 23, 2026, 14:46:39 pm
| | |-+  Broken lifter ?
Author Topic: Broken lifter ?  (Read 8411 times)
Rocket Ron
It's old school for a reason
« on: April 28, 2017, 19:15:57 pm »
Got a bit of a problem
My scat rockers rattled off a while ago whilst making a pass a shakey.  There now seems to a problem with the adjustment of the rocker arms. There is a significant difference in one of the rocker arm screw adjustment when adjusted compared to the rest. Thought I may have a bent pushrods but this seems fine. Is is likely to be a broken or damaged lifter or cam lobe.
Any advice gratefully received
Engine doesn't sound ticky or run rough
Thanks in advance
« Last Edit: April 28, 2017, 19:17:51 pm by Ron Elliot » Logged
13.12 @ 101.84
Grooving out on life
Rocket Ron
« Reply #1 on: April 28, 2017, 19:30:33 pm »
Ps rocker arms rotate freely but mounting block on rocker arms has a tight spot
13.12 @ 101.84
« Reply #2 on: April 28, 2017, 19:44:03 pm »
Does the pad that rubs on lash cap look ok, does it still have lash cap even? that would about right extra adjustment if it was missing
Otherwise most likely lifter failing, cam goes flat on nose which doesn't affect lash at zero as its set on other side of cam
Rocket Ron
« Reply #3 on: April 28, 2017, 20:01:15 pm »
hi Richie
Just double checked and the caps are all still on but the one on that valve is quite tight , just run the pushrod across the granite top in the kitchen, there's  approximately a 2mm lift when you roll it. would that be enough for the screw to be that far off ??
13.12 @ 101.84
« Reply #4 on: April 28, 2017, 20:33:13 pm »
Quite possibly, swap another pushrod into that hole and set lash, see how it looks then Smiley
Rocket Ron
« Reply #5 on: April 28, 2017, 20:39:38 pm »
Good idea, will give it a go
13.12 @ 101.84
« Reply #6 on: April 29, 2017, 18:41:36 pm »
Did you figure it out?
Rocket Ron
« Reply #7 on: April 29, 2017, 20:20:04 pm »
Hi Richie
Didn't get a chance to check until this evening. Defiantly seems to be the push rod. I swapped them over as you suggested and it puts the adjustment screw back where it should be.  Hoping to dust the car off so I can squeeze that 12 out of the car before I swap the motors over.  Wink
Thanks again for your help
Regards Ron
13.12 @ 101.84
« Reply #8 on: April 29, 2017, 20:35:55 pm »
Cool glad it is something simple Smiley
