October 01, 2026, 18:53:56 pm
| | |-+  Stick with the C35 or change the cam/go bigger
Author Topic: Stick with the C35 or change the cam/go bigger  (Read 13087 times)
2085 72 gtbug
« on: May 20, 2017, 19:57:40 pm »
OK guys I have all this lot ready to go together
The crank flywheel rods pistons pully and clutch are due out of the balancers on Tuesday
Case and barrels are being machined at the moment so with the spec listed am I under cam specced a little
As 41 dual relief case
Cb 74 crank
12lb flywheel
Kennedy stage 2
Dainken disc
Berg steel front pulley
Scat straight cuts
94 mahle non strokers
5.4 rods
Cb street elims 42/37
125 scat rockers
Big beef manifolds
48 idfs
Cb magna spark dizzy coil leads etc
Speed shop merged header and muffler
As I said I've got a scat c35cam kit lifters and springs to go with it but abouta week to change it if needs be
Thoughts please fellas
Cheers Chris
« Last Edit: May 21, 2017, 08:06:33 am by 2085 72 gtbug » Logged
mikko k
« Reply #1 on: May 21, 2017, 07:36:47 am »
For street bug? Go bigger. In my opinion.
2085 72 gtbug
« Reply #2 on: May 21, 2017, 08:10:14 am »
Sorry kiddo
Yep for mostly street use the car is full weight  (day moulding wings t bars etc)
And need it built run in and ready for the cal look drags in 8 weeks 😂
« Reply #3 on: May 21, 2017, 08:40:00 am »
Hi Chris
are heads ported? if so do you know by who? and how much/what port shape? engine warrants something bigger but only if heads will make use of it
« Reply #4 on: May 21, 2017, 09:55:16 am »
Web 121/125. Maybe advance the cam 2 degrees. 10-1 CR
2085 72 gtbug
« Reply #5 on: May 21, 2017, 12:17:17 pm »
Hi Chris
Hi Rich
I had the heads off here so don't know the history I will take some pictures this week and ping you an email
I was thinking only a c45 ish anyway
I'm thinking let it get built enjoy the car for a few weeks and drag day c how it plays out then get some opinions over the weekend....
Cheers Chris
« Reply #6 on: May 21, 2017, 18:45:51 pm »
C45 at a minimum.
UltraOrange67-2443
« Reply #7 on: May 22, 2017, 19:26:06 pm »
Webcam make some nice stuff
The heads are nicely ported and valve size is good.
Make use of the 48's  Grin
1967 1200 2920cc EFI
