October 12, 2026, 12:42:46 pm
| | |-+  Pros and cons of straight cut cam gears...
Author Topic: Pros and cons of straight cut cam gears...  (Read 8047 times)
Wejjy
« on: May 24, 2017, 21:29:39 pm »
As per the title, Im aware of the obvious ones like the whine, no thrust etc, but what are the advantages from a perceivable point of view. i.e longevity, noise levels etc as Ive never known anyone use them?
Thanks in advance.
RaptorLou
« Reply #1 on: June 22, 2017, 03:49:05 am »
Straight is all I use. Less power loss through gear set than helical gears. I like the whinnnneeee Grin
« Reply #2 on: June 22, 2017, 14:39:46 pm »
I once tested one of our local cars we have here that I played with for years, six cylinder engine, but still I think applicable.
Bore 92mm, stroke 76.2mm, 41.1/36.0 valves, pushrods, etc.
Anyway, going from helical gears to straight cuts, and an elec fuel pump instead of mechanical, gained (drum roll please......) 1.1/2 tenths and 1mph on a mid-15sec car.
I even reversed it all to double-check. See? It really IS a power mod.
 Cheesy
But really I just like the whine too!
« Reply #3 on: June 24, 2017, 20:48:18 pm »
.... going from helical gears to straight cuts, and an elec fuel pump instead of mechanical, gained (drum roll please......) 1.1/2 tenths and 1mph on a mid-15sec car.
How much lower was the oil temp with the straight cut gears?
« Reply #4 on: June 25, 2017, 03:58:45 am »
Dunno Bruce. this was on a water-cooled cast-iron engine (like a smaller version of your Chev 250).
I use them on ACVWs coz I like them, never bothered testing them.
