September 22, 2026, 21:24:37 pm
| | |-+  Early Porsche Steering Hoop
Author Topic: Early Porsche Steering Hoop  (Read 8052 times)
SlingShot
« on: May 27, 2017, 20:12:39 pm »
Anyone have experience using a early 911/12 Porsche Steering hoop in a beetle?
Will Race For Beer !!!
Taylor
« Reply #1 on: May 28, 2017, 04:50:13 am »
I have this one in my 67
SlingShot
« Reply #2 on: May 30, 2017, 03:31:00 am »
Does it fit right on ? Do you like the offset of the wheel?
Taylor
« Reply #3 on: May 30, 2017, 06:12:13 am »
It will fit the splines but won't work as is.  I had a spacer made similar to this one.
https://www.aasesales.com/products/h6h-f56-100w-105158
Then I had another piece machined to hold the stock vw turn signal cancellation ring.  I like the 180mm fit and offset.
« Reply #4 on: June 22, 2017, 19:43:03 pm »
i've  the VDM empi riverside 500 , i don't machined anything and fit correctly on my 61 , but i 've used a 65 steering columm with 65 tube , and use my 61 flashing arms , ( it's a 58 model)
« Last Edit: June 22, 2017, 19:44:41 pm by speedwell » Logged
gibber!
« Reply #5 on: June 23, 2017, 23:47:38 pm »
Here's mine....
As mentioned the wheel will it the column splines, but the plastic shroud will need to be removed from the rear of the steering wheel.
What I did was cut down the shroud so that 3/4mm of the splines were showing, then greased up the rear of the wheel and filled the shroud with epoxy resin after inserting a turn signal cancelling 'thing' from an old Bug steering wheel.
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
gibber!
« Reply #6 on: June 23, 2017, 23:50:55 pm »
....the back side
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
« Reply #7 on: July 05, 2017, 21:33:22 pm »
totally different with the empi riverside  will take a picture tomorrow
