October 13, 2026, 11:02:42 am
| | |-+  Early Porsche Steering Hoop
Author Topic: Early Porsche Steering Hoop  (Read 8598 times)
SlingShot
« on: May 27, 2017, 20:12:39 pm »
Anyone have experience using a early 911/12 Porsche Steering hoop in a beetle?
Will Race For Beer !!!
Taylor
« Reply #1 on: May 28, 2017, 04:50:13 am »
I have this one in my 67
SlingShot
« Reply #2 on: May 30, 2017, 03:31:00 am »
Does it fit right on ? Do you like the offset of the wheel?
Taylor
« Reply #3 on: May 30, 2017, 06:12:13 am »
It will fit the splines but won't work as is.  I had a spacer made similar to this one.
https://www.aasesales.com/products/h6h-f56-100w-105158
Then I had another piece machined to hold the stock vw turn signal cancellation ring.  I like the 180mm fit and offset.
« Reply #4 on: June 22, 2017, 19:43:03 pm »
i've  the VDM empi riverside 500 , i don't machined anything and fit correctly on my 61 , but i 've used a 65 steering columm with 65 tube , and use my 61 flashing arms , ( it's a 58 model)
« Last Edit: June 22, 2017, 19:44:41 pm by speedwell » Logged
gibber!
« Reply #5 on: June 23, 2017, 23:47:38 pm »
Here's mine....
As mentioned the wheel will it the column splines, but the plastic shroud will need to be removed from the rear of the steering wheel.
What I did was cut down the shroud so that 3/4mm of the splines were showing, then greased up the rear of the wheel and filled the shroud with epoxy resin after inserting a turn signal cancelling 'thing' from an old Bug steering wheel.
“There he goes. One of God's own prototypes. Some kind of high powered mutant never even considered for mass production. Too weird to live, and too rare to die.”
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
gibber!
« Reply #6 on: June 23, 2017, 23:50:55 pm »
....the back side
1967 1500 Beetle
1970 Karmann Ghia
SSVWC member
« Reply #7 on: July 05, 2017, 21:33:22 pm »
totally different with the empi riverside  will take a picture tomorrow
