September 23, 2026, 23:39:37 pm
| | |-+  Help with wiper arm replacement
Author Topic: Help with wiper arm replacement  (Read 6656 times)
stait9
« on: June 07, 2017, 20:51:37 pm »
Hello
I've recently had an issue with both locking screws on the wiper arms of my 1960 beetle sheering off.  Bugger indeed.  Anyhow, it seems the arms that were on the car are not standard or I simply cannot find the correct replacements.  It is a 1960 sedan.
The ones with the problem are thicker and the hole for the shaft is larger as well as the hinge being visible.  I bought some replacement arms which allegedly should fit bit they are totally different.  The brand name on my arms is: Granero.
Does anyone know what these are?  Where I can buy replacements?
Here's a comparison to what arrived (they are the skinny ones):
Please help someone as I am garage bound at the mo given the great british summer Smiley
Stuart
stait9
« Reply #1 on: June 07, 2017, 20:52:31 pm »
I have found these, has anyone bought these or knows of the company?
https://lanerussell.com/products/wiper-arms-beetle?variant=26177368072
« Reply #2 on: June 07, 2017, 22:39:08 pm »
You need the skinny ones. Lane Russel lists theirs as fitting 57-79? So wrong.
stait9
« Reply #3 on: June 08, 2017, 10:12:44 am »
Problem is the skinny ones don't fit the spindle which is in place.  I'm working on the idea that these may have been upgraded at some point.
67paulo
« Reply #4 on: June 08, 2017, 15:16:20 pm »
Contact Don at DLwest-Wiperguy
you can find him on The Samba, located in Oregon.......He is the best!
Jens-Ole
« Reply #5 on: June 08, 2017, 22:28:45 pm »
If you're not too picky about being original you can upgrade to 65-67 arms and 10" blades. They are both cheaper AND actually wipes the windscreen  Cheesy Cheesy
Larry S
« Reply #6 on: June 09, 2017, 15:52:15 pm »
I have used Don at DLWest and he is the go to guy on wipers and motors.
