November 02, 2026, 06:19:20 am
Technical stuff
48ida jetting q's
Topic: 48ida jetting q's (Read 7110 times)
Richierich56
48ida jetting q's
June 30, 2017, 23:39:21 pm »
Hi all.
In lieu of my new AFR gauge arriving, can anyone just give me an idea of whether this jetting will be a decent start point?
2276 motor, 86C, 44x37.5 heads with 52cc chambers, 1:4 rockers and 10:1 comp. Altitude is pretty much SL.
Carbs are EMPI 48's with 40 vents and:
165 mains;
200 airs;
60 idles;
F7emulsions
The carbs came off another motor and did have 150 mains in them which I guessed would be too small. This is just for a start point so any advice would be really appreciated.
Last Edit: June 30, 2017, 23:42:37 pm by Richierich56
Re: 48ida jetting q's
July 01, 2017, 06:30:36 am »
Looks a decent starting point, might want 65 idles, I would guess you would be inbetween 60s and 65s with that combo and 65s should make it drive smoother on the transition from idle to mains
neil68
July 04, 2017, 03:23:23 am »
I had a very similar engine: 2332 cc, 48 Weber IDAs, Web 86C, Scat 1.4 rockers, 10:1 CR, 44 x 37 044 oval ports, 54 cc chambers. The best change that I made was to ditch the F7 tubes that came with my IDAs and install F2 tubes. I ended up with 42 venturies, but 40's also worked well. Jetting was 65 idles, 210 air, 170 main and 2 mm needle valves.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
Dynojet Test:
Richierich56
July 05, 2017, 22:31:46 pm »
Cheers guys - hopefully sounds like I'll be in the ballpark then. Why would 150 mains be in there to start with - are they not way small for 48's?
neil68
July 06, 2017, 05:30:41 am »
If I recall correctly, 150 mains and F7 tubes are the original jets that came with IDAs along with the standard 37 mm venturies.
There is a formula in the literature that suggests the main jet should be ~4.0 to 4.3 times venturi size, therefore 150 mains with 37 vents is close. For 40 vents, you'd want 160-170 mains which I found to be fairly close.
I'm now up to 44 vents and 185 mains, with larger intake valves & cam. The dyno will tell you what works best for your engine.
Neil
Dynojet Test:
