September 22, 2026, 05:57:13 am
| | |-+  100HP 1600cc Engine builders help?
Author Topic: 100HP 1600cc Engine builders help?  (Read 28832 times)
Doogster
« on: July 11, 2017, 13:12:02 pm »
Being do a little bit of research before I dive in with an engine built, the plan is a hot 1600 to power a buggy.
Specs would be....
Stage 1 Heads from GAC in the UK.
Counterweighted Crank.
Stock Rods balanced?
Standard pistons balanced?
Lightened flywheel with 8 dowel.
Engle 110 cam
twin 40's
full flow oiling.
SO hoping for 100hp and 6000 RPM with that.  Is that possible?
« Reply #1 on: July 11, 2017, 16:42:43 pm »
Speak to GAC - they are the experts at getting power from small engines (Formula Vee etc). It will be all down to head work – and the right cam and exhaust.
Doogster
« Reply #2 on: July 11, 2017, 19:33:20 pm »
Spoke with Alan at GAC today, really really helpful, I am away to strip my heads of and send them down to him and take it from there. Wink
2085 72 gtbug
« Reply #3 on: July 11, 2017, 20:19:05 pm »
Kieth is spot on
My old spec engine really gac heads which Alan did plus he did the match porting on the manifolds to
Car ran an engle 100
Plus a really good exhaust  (turbo Thomas)
Oh and good ignition
Did 98bhp on the rollers
Chris
Doogster
« Reply #4 on: July 11, 2017, 20:25:46 pm »
Kieth is spot on
Chris
That's good to know,
DO you know what the whole spec was of the engine mate?
2085 72 gtbug
« Reply #5 on: July 11, 2017, 20:51:56 pm »
As 41 case drilled tapped full flow
Genuine vw crank
Genuine vw flywheel
Gene Berg steel pulley
Kennedy stage 1
5.4 chromo rods
All Dymo balanced at Andersons racing Bath
Genuine mahle b&p's weighed to match up
Gac heads autolinear vw
Genuine nos 36 dellortos on matchported manifolds
Cb ignition
Exhaust as mentioned above
1500 4.125 r&p gearbox bracebar midmount
« Reply #6 on: July 11, 2017, 22:20:28 pm »
Wow! lots of people build big motors and end up with 120hp.  Cry
brian e
« Reply #7 on: July 11, 2017, 22:58:33 pm »
Genuine vw crank
Genuine vw flywheel
Kennedy stage 1
5.4 chromo rods
Cb ignition
What cam and compression?
Doogster
« Reply #8 on: July 12, 2017, 08:18:54 am »
One of the reasons I want to do this hot 1600, see what can reliably be done. (and its a light car)
Speaking with Alan at GAC he said 100bhp and 100ib torque.
Doogster
« Reply #9 on: July 12, 2017, 08:22:06 am »
Genuine vw crank
Genuine vw flywheel
Kennedy stage 1
5.4 chromo rods
Cb ignition
Same question. I was thinking 9:1?
kever65
« Reply #10 on: July 12, 2017, 19:48:21 pm »
(1600ccx5500rpmx10.5)/910000=101.5 hp
Verstuurd vanaf mijn GT-I9505 met Tapatalk
2085 72 gtbug
« Reply #11 on: July 12, 2017, 19:57:12 pm »
Sorry can't answer that guys as the motor was installed...but it pulled like a train great fun....
Will update on my new motor soon lol 2054 48idf on the same case 😉
Doogster
« Reply #12 on: July 12, 2017, 20:26:13 pm »
Sounds good I am looking forward to putting this together. Was all about an 1835 or 1776 or similar until I spoke with a few people and decided if we can get 100bhp from a 1600 it sounds like a fun little motor.
2085 72 gtbug
« Reply #13 on: July 12, 2017, 21:35:42 pm »
[/quote
Keep at it fella
Think as kieth said choices are key and my motor revved so well so balancing also paramount...
With my new build I've gone down that route and had all that done again by a well respected race shop in Cheshire
Front pulley crank flywheel plate rods pistons all Dymo balanced...
Look forward to seeing your results
Chris
Doogster
« Reply #14 on: July 13, 2017, 09:38:09 am »
[/quote
Keep at it fella
Chris
Cheers Chris, do you have a built thread going on yours?
« Reply #15 on: July 13, 2017, 10:29:27 am »
I liked the engine from Johannes from JPM, I think he made a 1600 engine out of a 1200 crank 64mm and 90.5mm pistons making it 1647cc.
With very impressive HP an RPM figures. Always thinking in my head to built one of those.
Hope you will post progress here on the lounge.
Doogster
« Reply #16 on: July 13, 2017, 12:59:42 pm »
Sounds a really interesting engine!  Would like to see the build up of it!
I have just go of the phone to stateside tuning here in the UK, they are going to supply me a counterweighted crank and flywheel, I am going to send them down my conrods as they do an exchange service on these for some balanced ones. (I will sort of the pistons myself with a dremel)
Whilst speaking with James @ Stateside, he asked what I am trying to get out the engine so I explained it and he said I am maybe better going with a VZ30 Cam. (downside being I may only get 10000 Miles out my valve train)
« Reply #17 on: July 13, 2017, 13:24:38 pm »
I think it is on here
http://cal-look.no/lounge/index.php/topic,3257.30.html  2nd page somewhere in the middle. Ok not a 64x90.5 engine... thought I came across that one too.
Hello!
After following this very interesting thread I have decided to build a "mouse motor" with almost only original parts and by using some simple math and sience.
Engine spec:
Case: original AS41
Crank:German stock
Rods:German stock
Pistons:JE 86mm 24mm comp hight
Cylinders:Stock 85,5mm honed to 86mm
Heads:043 40x32mm valves
Compression:12,0:1
Rockers:Jpm two stud 1,5:1 ratio
P-rods:Manton 3/8" cromoly
Cam:Fk45in/Fk44 ex
Cam gears:Magnum
Oilpump:26mm
Deepsump:1,5lit
Flywheel:180mm stock lightend
Clutch disc:cush lock
Pressure plate:Kennedy
Header:Custom made 1 5/8" tuned length
Manifolds:Custom made tuned length(second order)
Carbs:IDA 48
The most expensive parts in this concept is the JE pistons, but I feel they are nessecery if the calculated power should be optained.
All the parts will of course be inspected and modified(linebored,shuffle pinned,balanced,fullflowed etc..........) to take the higher output.
Heads:
The heads will recive a little welding in some areas and ported to achive as high flow as possible in the limitations of the calculated port size.
Cam:
I will use a cam with split duration, fk45 intake and fk44 exhaust.The less ex duration will give a superior midrange without loosing top end, if the ex port flows enough, a good choise when using a "Hi-Po" engine on
the street.
I have decided to use a 40mm intake valve because of the 86mm bore, and the valve will not be moved to the center of the cylinder,a bigger valve will be to much shrouded from the cylinder wall.
Calculation:
The formula I will use to see how much rpm the 40mm valve will be good for is:
RPM=3300000xPort dia xPort dia/BorexBore xStroke
This formula is based on a mean port velocity at 110m/s or(360ft/s), and the Port dia is the smallest area in the port.
As this engine is going to be used as a street engine the smallest port size I will use is 0,88 x valve dia(0,88x40=35,2mm)
RPM calculation:3300000x35,2x35,2/86x86x69=8012rpm
The teoretical rpm where peak power will be is 8012 rpm.
Now we have the RPM,diplacement but not the Bmep, a realistic Bmep is between 12-13 bar(171-185psi), so I choose 12,5bar Bmep.With this information we can calculate the POWER of the "mouse motor".
Formula:
P=Displ x rpm x Bmep/910
POWER=1,603 x 8012 x 12,5 / 910 = 176,4hp
This is the power that could be expected from the "mouse motor" if everything is properly done.
With properly done I mean everything like heads,compression,cam timing,exhaust length,intake length,friction etc.....................  .
I will start on this project in the next week but as I run a company it will take some time to finish it, probably in mars 2008.
During that time I will keep you updated with pictures and info as the project continous.
When the "mouse motor" is done there will be som serious dyno testing and tuning, hopefully we will see the numbers that i come up with in the calculations above.
To me,this is what I belive is "Thinking outside the box" and "The next level".
With Best Regards
Johannes Persson
JP Motorsport
Sweden
2085 72 gtbug
« Reply #18 on: July 13, 2017, 15:51:09 pm »
My engineering/balancing guy polished/balanced  all my crank rods pistons for £185....
You could do with getting all your rotating parts balanced together and your rods weighed/balanced to...
Use Jim to get your pistons done might seem a cost but worthwhile
Chris
Doogster
« Reply #19 on: July 13, 2017, 16:26:48 pm »
Chris
I shall do,  its all money well spent though, I don't think any point in half assing on costs when trying to build a quick little engine.
I want something that will last a wee while before it goes bang. Smiley
Joel Mohr
« Reply #20 on: July 13, 2017, 23:13:05 pm »
https://www.youtube.com/watch?v=ErJdyA9G6N8
120 at the crank 72 x 85.5 35 x 32 040 heads with 6mm stems and beehive springs
WEB 122, 44 idfs
 3 step header
« Last Edit: July 14, 2017, 16:10:30 pm by Joel Mohr » Logged
SEE YA AT THE RACES!!!
« Reply #21 on: July 14, 2017, 02:39:19 am »
Looks like the perfect car to go with it.
What rpm was that?
Doogster
« Reply #22 on: July 14, 2017, 08:35:47 am »
120 at the carnk 72 x 85.5 35 x 32 040 heads with 6mm stems and beehive springs
WEB 122 44 idfs
 3 step header
Crikey that's impressive! Same questions as Martin?
Joel Mohr
« Reply #23 on: July 14, 2017, 16:08:49 pm »
Peak HP was at 6800 The Web 122 is .506 x 288. The heads just had a clean up P&P by Clyde Berg....I was hoping for 100, overshot it a bit...damn...car is 1600# Berg 5 speed, ran 14.60 spinning all the way through 1st gear...(no slicks)
« Last Edit: July 14, 2017, 16:14:12 pm by Joel Mohr » Logged
« Reply #24 on: July 14, 2017, 17:03:17 pm »
That's impressive! What was the torque?
Joel Mohr
« Reply #25 on: July 14, 2017, 19:59:06 pm »
97 at the wheels.... the heads were hemi cut and 9 to 1 on 91 octane
Doogster
« Reply #26 on: July 14, 2017, 20:47:25 pm »
Just watched that video again dude, that an impressive little motor!!!!
« Reply #27 on: July 15, 2017, 03:14:22 am »
The most interesting part of this is the chamber. The project here is 12:1. That motor was semi hemi 9:1. That's a big difference in design.
And I'm trying to picture what the SH would look like at 9:1. Kissing at the edges? Smaller dip in the middle?
When I ran a Berg type motor it was 7:1 lol.
Joel Mohr
« Reply #28 on: July 17, 2017, 16:21:47 pm »
The Hemi cut in the chamber was cut to the bore diameter, 52cc's and 0 deck..
Doogster
« Reply #29 on: July 17, 2017, 20:18:27 pm »
Who did the Hemi cut for you Joel?
