November 02, 2026, 07:33:21 am
Latest Member: thunder_bac
| | |-+  Setting adjustable spring plates with heavy duty torsion bars
Author Topic: Setting adjustable spring plates with heavy duty torsion bars  (Read 7965 times)
vwhelmot
« on: July 12, 2017, 18:35:19 pm »
I`ve got a set of sway away heavy duty rear torsion bars along with a set of saw adjustable plates. Do I set the sag angle at 18 degrees as standard or because the bars are so much thicker do I set them at a lower degree? Is there enough adjustment on the plates to drop the car down a touch if I do set them at 18 degrees?  I want the m+h street tyres to fill the arches if you know what I mean.
« Reply #1 on: July 12, 2017, 18:47:12 pm »
I set them with no preload, so spring plate just rests on factory stop with 26mm and thicker bars
vwhelmot
« Reply #2 on: July 12, 2017, 19:01:00 pm »
Bloody hell! Is there any rear suspension movement at all?
« Reply #3 on: July 12, 2017, 19:24:15 pm »
I personally don't think its much stiffer than stock like that with 26mm bars, just about no camber on swingaxle cars and ride height is about right
vwhelmot
« Reply #4 on: July 12, 2017, 19:39:10 pm »
Cheers Ritchie, I'll set them to no sag. I can fine tune them with the adjustable plates.
Chip
« Reply #5 on: July 12, 2017, 20:06:29 pm »
I just put 29s in my street car. I set them much like richie describes, though mine sits a little bit on the lowered side(by design). The car rides just fine. Its 2000lbs with me in it though.
« Reply #6 on: July 12, 2017, 20:40:55 pm »
Other thing to remember is the longer they are the softer for given diameter, 26mm short is a lot stiffer than 26mm long
