November 04, 2026, 13:53:51 pm
new idea with the GB dipstick, well maybe...
Topic: new idea with the GB dipstick, well maybe... (Read 7752 times)
oval57
October 08, 2007, 21:14:06 pm »
I have a Gene Berg dipstick temp gauge. At £18 and no gauge to clutter my dash i'm happy with it. Ish. Have you ever used one of these to check you oil? its not good. Gold anodised with fresh oil and the wire gets caught on the alternator... it's a mess.
I'm thinking of running a T3 dipstick convertor in my AS41 and modding it to poke out near my main dipstick tube. Thus runnign a stock dipstick and the GB temp in the T3 tube.
Should work you think?
Re: new idea with the GB dipstick, well maybe...
October 09, 2007, 02:18:16 am »
Yeah, Berg didnt think it through with that idea. In the Slingle Cab the GB227 is mounted in the old Treuhaft sump- older sumps have a built in threaded boss.
On a side note, I believe the oil temp sending unit should be mounted in the sump- oil is at its hottest temperature there, and the the hottest temp is what you want to know.
October 09, 2007, 02:38:20 am »
I just keep my regular dipstick in the glove compartment for when I want to check oil.
October 09, 2007, 22:45:39 pm »
This Gene's personal recommendation when you use the Gene Berg dipstick.
Trent B
October 10, 2007, 20:29:36 pm »
Donny B. is that a zerk fitting on your linkage pivot arm? (!)
Rune
SCC Crew
Screwdrivers #7
October 10, 2007, 20:34:57 pm »
I like theyr shorty sender.
http://www.geneberg.com/product_info.php?cPath=2734&products_id=259
October 10, 2007, 22:40:07 pm »
Quote
Yes it is. I thought it would make it easier to keep the thing lubricated. Just attach the grease gun and pump once and it's done.
Trent B
October 11, 2007, 05:50:40 am »
great idea, looks trick too...
