September 22, 2026, 02:35:22 am
| | |-+  DTA S60PRO oil/fuel pressure senders
Author Topic: DTA S60PRO oil/fuel pressure senders  (Read 5194 times)
Erlend / bug66
Global Moderator
SCC Event
« on: July 21, 2017, 22:46:46 pm »
Hi,
Do some of you have a better source of compatible senders than DTA themselves? 100£ per sender is just stupid..
Maybe oil temp as well?
Thanks,
Erlend
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
Chip
« Reply #1 on: July 21, 2017, 23:29:52 pm »
I've used these with good success.  Oil, e85, exhaust...
http://www.ebay.com/itm/261260635816
I would assume gm fluid temp sensors will do the trick with the dta. I use one for oil, water and air temp on my setup.
Erlend / bug66
Global Moderator
SCC Event
« Reply #2 on: July 23, 2017, 01:14:21 am »
Thanks! under 20% of DTA's price  Roll Eyes
Used them on DTA? I'm trying to figure out which senders are compatible Smiley
The '67:
The '59:
Not yet..
Chip
« Reply #3 on: July 23, 2017, 07:17:36 am »
I use them with my MS3-Pro. My bet is that the DTA is just looking for a 0-5v signal.
Check under sensor scaling or something like that to adjust what the ecu reads from the sensor.
« Last Edit: July 23, 2017, 07:21:56 am by Chip » Logged
