September 20, 2026, 19:02:28 pm
Latest Member: Bad Habit
| | |-+  Accelerator Return Spring
Author Topic: Accelerator Return Spring  (Read 5294 times)
RichardinNZ
« on: July 30, 2017, 21:58:12 pm »
I'm having trouble with the throttle sticking on my dual carb 36hp.  I was running the original 36hp spring over the accelerator cable, between the end of the cable and the fan shroud.  However, this wasn't great as it interfered with the arc that the cable wants to move through.  I think some crossbars have return springs.  These are the ends of my bar.  Any ideas as to where I can find some?  I think CSP use a spring on one end I but I'd be tempted to add one to each end?
Richard
'58 Bug; NZ assembled
Dual Carb 36hp
RichardinNZ
« Reply #1 on: July 30, 2017, 22:01:35 pm »
The photos..
Sent from my SM-N920I using Tapatalk
Dual Carb 36hp
RichardinNZ
« Reply #2 on: August 07, 2017, 02:47:01 am »
Resolved...I'm having two springs made which will fit around each end of the cross bar.
Dual Carb 36hp
