September 24, 2026, 01:29:44 am
| | |-+  oxyboxer engine.
Author Topic: oxyboxer engine.  (Read 12639 times)
Bad bug
« on: August 01, 2017, 20:10:43 pm »
Good day guys,
I am building a 2.2ltr oxyboxer with the new los panchittos head and would love to know which exhaust system will allow me to run all the engine tins available.
Urbantoy
« Reply #1 on: August 07, 2017, 08:28:12 am »
Hello,
I am not sure if You are aware about this forum:
http://shoptalkforums.com/viewforum.php?f=37
Bad bug
« Reply #2 on: August 12, 2017, 21:35:07 pm »
I know about it, i post there sometimes just wanted input from people across the pond who are more familiar with oxys.
bedjo78
« Reply #3 on: August 12, 2017, 23:34:19 pm »
some merge not clear oil filter. otherwise all good
karl h
« Reply #4 on: August 14, 2017, 06:40:22 am »
how are you going to mate the waterboxer headstuds to the heads?
LGK
« Reply #5 on: August 14, 2017, 12:42:16 pm »
I was thinking the same Karl but he can always "offset the case savers" as rocky Jennings is doing.
Rgds Steve
Jens-Ole
« Reply #6 on: August 24, 2017, 13:22:30 pm »
If you need to run the lower tins also I'd say CSP Python, otherwise go classic merged  Wink
Bad bug
« Reply #7 on: August 28, 2017, 00:00:19 am »
Rgds Steve
That's it, rocky is offsetting the case savers for me.
« Last Edit: September 10, 2017, 09:02:41 am by Bad bug » Logged
Bad bug
« Reply #8 on: August 28, 2017, 00:01:32 am »
Looking to full flow the case so the original location for the oil filter will not be used.
Bad bug
« Reply #9 on: August 28, 2017, 00:02:31 am »
I will check this out.
Grelland
« Reply #10 on: September 06, 2017, 22:14:44 pm »
CSP Python on my 2110 oxy. I am using a sandwich plate between case and filer, but still ok clearance.
___________________
Roy
Martin S.
« Reply #11 on: September 07, 2017, 23:05:33 pm »
I love the exhaust wrap!  Grin
Dalland
« Reply #12 on: September 08, 2017, 09:42:11 am »
A pleasure to work with and newer gets brittle.
This size is 42 mm when stretched and 2,5" when full expanded. Grin
Its me that where selling these, maybe I will see if enough people here want it as i have to order 100++ meters minimum. Wink
Bad bug
« Reply #13 on: September 10, 2017, 09:01:29 am »
Rgds Steve
That's what i am doing. Rocky Jennings is doing the engine machining.
Bad bug
« Reply #14 on: September 10, 2017, 09:07:14 am »
Grelland is that exhaust stainless steel, do you have a part number for the exhaust, what is the power like with this header.
