July 16, 2026, 20:21:28 pm
352235 Posts in 28933 Topics by 6923 Members
| | |-+  CB Performance rotary pump capabilities?
Author Topic: CB Performance rotary pump capabilities?  (Read 7497 times)
« on: August 05, 2017, 13:22:40 pm »
I have used successfully the CB Performance rotary 3.5psi pump on my 2276cc oval. I like it as it doesn't require a separate regulator.
Thinking about what pump to run on the Notch, initially running a 230-240 bhp normally aspirated motor. Will the CB pump cope with that?
flatfire
« Reply #1 on: August 06, 2017, 10:46:37 am »
I have used a rotary pump for years. Was having lots of problems with my new motor running 48idas. Before I hooked up the rotary I replaced the filter. Curious as ever I cut it in half and it was pretty clogged up. Sucking out of ancient petrol tanks😊. Anyway I attached a gauge to check the pressure it was bang on 3psi after all these years. I measured flow into a jug more than enough for a 200hp engine.
neil68
« Reply #2 on: August 08, 2017, 04:30:38 am »
I received a pm on another forum, from someone who mentioned to me that switching from the CB Carter rotary pump to another pump (I believe a Holley) moved their Beetle from stubborn low 12's to well into the 11's in the 1/4-mile first time out.
Neil
Der Kleiner Rennwagens
'68 Beetle, 2332 cc, 204 WHP
« Reply #3 on: August 08, 2017, 08:12:52 am »
That's interesting. Wonder why that would make so much difference?
jim martin
« Reply #4 on: August 09, 2017, 06:08:02 am »
Was most likely running bowls low .
Now new pump keeps them full , no more lean due to low fuel level
B.C's fastest street legal vw , June 2006 Hot VW's feature car  9.812 at 145.26 mph
Sponsored by :
     LUCAS OIL PRODUCTS   http://www.lucasoil.com
     KROC head porting services
     Dialedinperformance.com
« Reply #5 on: August 09, 2017, 09:06:11 am »
No
« Reply #6 on: August 09, 2017, 09:38:02 am »
Thanks guys,
Looks like a new pump is required. What colour Holley is needed for Ida's?
Is there a better alternative?
« Reply #7 on: August 09, 2017, 22:20:40 pm »
i like the mallory pump and matching regulator (return style)
