September 23, 2026, 17:05:20 pm
| |-+  For sale!
| | |-+  VW - 51 street racing beetle
Author Topic: VW - 51 street racing beetle  (Read 3393 times)
Jukkis Maki
« on: August 05, 2017, 21:47:23 pm »
Maybe the world's most iconic VW street racing beetle?
Genuine -51 steel body with OG lids, instruments, bumbers, doors etc. Custom-made rollcage for this car. Autometer + VDO gauges. Ultra thin windshield and carbonate windows. Aluminium door panels. Aluminium fuel tank and Facet hipo fuel pump with Summit pressure regulation + filter + new fuel lines. Optima Redtop.
-51 floorpan with new panels and reinforcened rear fork for gearbox + solid gearbox brackets. Linelock, new brakelines, hoses and cylinders. 29 mm torsion bars and adjustable spring plates from Sway-a-way + billet Easthill Welding spring plate covers. QA1 adjustable rear shocks and Competition Engineering adjustable front shocks. 2,5” narrowed new front axle with new pushings, bearings + king and links pins and modified NOS -62 brakes. New NOS rear brakes Typ3.
Gearbox build by Mats Herrlander with Rhino case, Weddle proring gears, JayCee spool, aluminium side covers and unbreakable Karpiola axles. 12 starts.
82x94 engine. Reinforcened AS41 case, genuine Gene Berg 82 mm axle and lighteden GB flywheel, CB racing H-profile rods, modified C-65 cam, Scat ultralight lifters, Mahle hipo pistons and cylinders + Clavite 77 and Kolbensmith bearings. MSD 6AL ignition, distributor and coil. Fullflow, Mellings oil pump and Mann oil filter system. NOS SuperFlow heads (prepped) with stainless steel valves 48/38 mm, double springs and titanium retainers. Pauter 1,5 rockers. 51,5 IDA’s by JayCee and Gene Berg 1 5/8” headers + stinger and Magnaflex silencer. CSP chromoly case stud kit and oil breather box, JayCee tubes and Scat sticks, NOS doghouse oil cooler etc. Not a single part manufactured in China. 224 hp / 275 Nm with 7200 rpm. Some testsarts ET 12.40 / 171 kmh on slippery and bumby airfield track.
Shipping worldwide. NL and Belgium 800€, Lûbeck 600€ , California / USA 2000$
Turn key and drive! Valid TÛV until 2018
24900 €
« Last Edit: August 22, 2017, 08:14:55 am by Jukkis Maki » Logged
Jukkis Maki
« Reply #1 on: August 22, 2017, 08:16:14 am »
Up
