October 12, 2026, 16:46:01 pm
| | |-+  Welded Crank rod journals
Author Topic: Welded Crank rod journals  (Read 6147 times)
Eddie DVK
« on: August 12, 2017, 09:04:30 am »
Are maybe one of you guys run into trouble with rod journal sizes on a welded stroker.
Bought a welded type 4 76 mm crank (second hand, but supposed to be never used) but rod size are so far off, that the rods can not spin freely.
They jam on some areas of the journal. You can also wiggel the rods around on the journal.
Measured the journals and they are 0.20mm of on certain areas. Shocked  Cry  Angry
Help appreciated
Regards Edgar
Regards Edgar
« Reply #1 on: August 12, 2017, 11:58:43 am »
Have it ground? At least it's over I guess
Eddie DVK
« Reply #2 on: August 12, 2017, 12:07:31 pm »
Yeah well, that is what I am going to try, if possible.
But just wondering what the cause could be that it is way off.
And if someone else has encountered this.
Regards Edgar
Regards Edgar
Eddie DVK
« Reply #3 on: August 15, 2017, 14:59:01 pm »
Nobody else run into this problem with a welded crank?  Undecided
Regards Edgar
Martin S.
« Reply #4 on: August 15, 2017, 15:07:37 pm »
Sell it and buy a new one.
« Reply #5 on: August 15, 2017, 16:30:43 pm »
No never seen one like that, do you know which brand it is Eddie?
