September 24, 2026, 22:41:21 pm
Keeping a "Type1" swingaxle case alive..?
Topic: Keeping a "Type1" swingaxle case alive..? (Read 12799 times)
Erlend / bug66
Global Moderator
SCC Event
August 20, 2017, 19:54:24 pm »
Is there a good thread out there?
Alunimium house I presume..
Big or small gussets?
Steel plates and bolts to hold the side plates?
Help wanted.. Snapped a gearbox in two..
Last Edit: August 20, 2017, 22:28:25 pm by Erlend / bug66
The '67:
10.626 @ 132mph, SCC 2016
10.407 @ 134mph, SCC 2017
10.221 @ 135mph, SCC 2018
The '59:
Not yet..
numbnuts
Re: Keeping a "Type1" swingaxle case alive..?
August 20, 2017, 23:10:46 pm »
Wow that's some breakage
Been reading up on t2 boxes as they are stronger. What is the set up of the car?
2854cc 1956 cal looker coming to this space shortly
Erlend / bug66
Global Moderator
SCC Event
August 21, 2017, 14:36:22 pm »
Quote from: numbnuts on August 20, 2017, 23:10:46 pm
Let's see.
Full weight 67 bug.
400whp / 535nm to the wheels.
Stage 4 + black magic
hydraulic clutch management
KCR built box on gusseted mag case, full weddle internals included what was an Weddle R&P...
Rhino case and bolted sideplates next..
The '67:
The '59:
Not yet..
August 21, 2017, 17:36:30 pm »
Might be time to step up to a bus box. I'm sure Richie will be along shortly, but he was in a similar place back in the early '00's and he did a box virtually identical to yours.
It does mean IRS, but thats no bad thing really!
August 22, 2017, 12:57:12 pm »
For this you need a bus box with folts or rancho axles. We just got one from rancho. Complete with IRS to swing axles
www.Udobeckertuning.de
Erlend / bug66
Global Moderator
SCC Event
August 22, 2017, 13:24:27 pm »
Quote from: Udo on August 22, 2017, 12:57:12 pm
Does Folts axles handle 400-500 ft.lbs to the tires and sub 1,4 60-foot times?
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
August 22, 2017, 13:27:59 pm »
And I've got a lot of swingaxle spares, so not really keen on going IRS..
The '67:
The '59:
Not yet..
Erlend / bug66
Global Moderator
SCC Event
August 23, 2017, 09:28:19 am »
New main gearbox will now be:
White Rhino main house
Weddle/Mendeola gear carrier housing + nosecone
Paul Guard diff
full Weddle race gear stack
Hopefully a Weddle R&P
Full circle sideplates with through bolt
Gearbox girdle/cradle thingy..
The '67:
The '59:
Not yet..
Dougy Dee
August 23, 2017, 14:35:39 pm »
What were you using to control ring & pinion movement?
Erlend / bug66
Global Moderator
SCC Event
August 23, 2017, 14:48:30 pm »
Quote from: Dougy Dee on August 23, 2017, 14:35:39 pm
What do you mean? Gusseted mag case. But that did not hold..
The '67:
The '59:
Not yet..
August 24, 2017, 06:25:49 am »
Quote from: Erlend / bug66 on August 23, 2017, 09:28:19 am
Paul Guard diff
You should use another clutch with this ...
Erlend / bug66
Global Moderator
SCC Event
August 24, 2017, 06:53:19 am »
Quote from: Udo on August 24, 2017, 06:25:49 am
Paul Guard diff
As in what type?
The '67:
The '59:
Not yet..
August 25, 2017, 13:19:13 pm »
Is there such a thing available as a staged lock-up clutch (like on my bike......
http://www.mtceng.com/index.php/technical-information/7-clutch-differences
NoBars
September 02, 2017, 01:22:39 am »
Quote from: modnrod on August 25, 2017, 13:19:13 pm
Rev6. It's actually more similar to a gen2 multistage than a lockup or multistage as the weights are on the engine side of the clutch, not the input shaft side.
gkeeton@zbzoom.net
September 03, 2017, 04:23:07 am »
http://www.shoptalkforums.com/viewtopic.php?f=50&t=89944&start=45
