September 19, 2026, 06:35:46 am
Latest Member: Bad Habit
| |-+  Technical stuff
| | |-+  Oil filter question
Pages: 1 [2] Print
Author Topic: Oil filter question  (Read 25146 times)
« Reply #30 on: August 22, 2017, 19:48:04 pm »
Oil pressure loss does not mean a seized engine. We've all seen engine blow contests. Not too long ago a chunk of metal got sucked up (no oil screen) and stopped my oil pump dead. I drove back into my garage after going around the block and luckily there was no damage at all and I just replaced the pump and the engine is fine still. If your bearings are too tight, don't blame the oiling system.
baz
« Reply #31 on: August 22, 2017, 20:06:49 pm »
My engine temporarily seized because no 2 locked on the journal,  it spun over by hand a few hours later.
This is the bearing.
Also when the motor seized it was the coldest it had been all day,  it was turned off for 30 mins while oil lines were removed to try stop the leak. It had been running fairly hard before then for an hour so I'd imagine the tight rod bearings would have caused issues earlier. Things only went bad once the oil filter spat shit back into the motor.
« Last Edit: August 22, 2017, 20:20:48 pm by baz » Logged
I will prevail.
« Reply #32 on: August 22, 2017, 20:18:17 pm »
Ugh, that sucks! You'd think he would have an eye on the oil pressure when firing up a new engine. I don't understand how people can assemble an engine that won't turn over by hand. Expecting tight bearings to break in is a mistake. The good news is that it happened on the dyno, and not while driving.
Richierich56
« Reply #33 on: August 22, 2017, 21:23:07 pm »
I'm not surprised you're pissed.
« Reply #34 on: August 22, 2017, 21:34:24 pm »
How does the crank look? Is it blued at all? Seems to me if the crank was damaged it is almost not worth fixing. New cranks are only around $250. Has anyone had crank work done lately, and what was the cost.
Richierich56
« Reply #35 on: August 22, 2017, 22:20:32 pm »
I think Baz is in the UK like myself Martin and unfortunately, good quality cranks here are a fair bit more than that. Hopefully not needed!
baz
« Reply #36 on: August 22, 2017, 22:35:02 pm »
Crank wasn't blued just scored on every journal. Rods weren't blued either.  It was a dpr std std crank,  it was grinded 1st under to fix it. Yeah I'm in UK stateside had it done by their guy.
I will prevail.
« Reply #37 on: August 23, 2017, 01:51:17 am »
Scored on every journal - that's insane. Consider plastigauging it this time to be sure.
« Reply #38 on: August 23, 2017, 02:14:05 am »
Since we started talking about bearings I always think back to Steve's advice about clearances. I have an informative 2 minute YouTube for you where he talks about the importance of bearings in the Type 1 motor from a guy that probably swapped more of them in his short life than we can only dream of. https://youtu.be/K7djBcHGKYg?list=PLDI904iuOabMy11qRAy6WyvyA4akJdhcL
Pages: 1 [2] Print
